Author Topic: F1 Clutch cable  (Read 6192 times)
Offline Skoti
F1 Clutch cable
« on: February 09, 2010, 05:48:00 PM »
Hi,
my CB750F1 handle bars are a touch wider and taller than standard which makes the clutch cable stretch when on full left lock.
Anyone know of a good source for slightly longer clutch cables?   :-\
Skoti
1976 Honda CB750F1
Offline Yoshi823
  • Biker to the bone...
Re: F1 Clutch cable
« Reply #1 on: February 09, 2010, 10:05:08 PM »
I had been going to suggest Venhill Engineering www.venhill.co.uk until I realised where you are based.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Re: F1 Clutch cable
« Reply #2 on: February 10, 2010, 08:25:00 AM »
Have a look for US spec F1 cables, their bars are higher and wider, should be able to find something on the CMS NL or David Silver websites.
http://www.cmsnl.com/
http://www.davidsilverspares.co.uk/
Den
Offline Skoti
Re: F1 Clutch cable
« Reply #3 on: February 10, 2010, 08:57:38 AM »
I'll be in the UK next week, but I see Venhill don't list any cables on their website for CB750F1/F2  :(
Skoti
1976 Honda CB750F1
Offline Skoti
Re: F1 Clutch cable
« Reply #4 on: February 10, 2010, 09:03:16 AM »
Den
Thanks for that, but I think the US spec cable might be a bit too long. The US spec bars seem quite high and wide compared to mine.
I see that according to frame numbers there are two different cables listed on www.cmsnl.com for the F1 anyone know what the difference is?
Skoti
1976 Honda CB750F1
Offline Yoshi823
Re: F1 Clutch cable
« Reply #5 on: February 10, 2010, 09:40:31 AM »
Venhill made me a clutch cable for my XR400 enduro bike. It's better than the OEM one. I'm sure that they could make you a one off if they had an original to work from. If you make the point that they could then push the product to the vintage bike clubs they wouldn't be just making a one off.
Yamaha R1 2001
Honda XR400R 1997
Honda CB125T2 1980
Re: F1 Clutch cable
« Reply #6 on: February 10, 2010, 10:01:34 AM »
There is a difference in F1 clutch cables, when I ordered mine at David Silver Spares they asked for the engine number. I presume there is a difference at the clutch end but I'm not sure, try giving therm a call or e mail them.
Den
Offline mick
Re: F1 Clutch cable
« Reply #7 on: February 10, 2010, 10:34:52 AM »
Hi Skoti, you could also try www.z1enterprises.com they are based in the US i have used them before with no problems  ;) cheers mick.
« Last Edit: February 10, 2010, 10:39:51 AM by mick »
Offline Skoti
Re: F1 Clutch cable
« Reply #8 on: February 10, 2010, 05:18:34 PM »
Good web site at Z1 enterprises, they detail the length of two different clutch cables listed for the F1. The smaller of the two will do me just fine  :) Thank you Mick.
Skoti
1976 Honda CB750F1
Re: F1 Clutch cable
« Reply #9 on: February 10, 2010, 05:55:27 PM »
Jeff Saunders (the proprietor of Z1) is a member at www.sohc4.net (his username is Jeff.Saunders I think)
He is a regular contributor and is expanding his range away from just Z1s to Hondas as well.
