CB350/400
Sudden Loss Of Drive. CB350F
Topic: Sudden Loss Of Drive. CB350F (Read 10709 times)
gtmdriver
SOHC Expert
Re: Sudden Loss Of Drive. CB350F
Reply #15 on:
July 27, 2021, 07:45:07 AM »
The M6 screw jammed the external linkage. It was outside the gearbox and jammed between the engine casing and the lever that the clutch cable connects to. Still need to find where it came from though.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Reply #16 on:
July 27, 2021, 07:46:40 AM »
Probably thrown up by the front tyre.
Normally they end up embedded in the rear
taysidedragon
Reply #17 on:
July 27, 2021, 12:53:21 PM »
Has the bolt fallen out of the cam cover or breather cover? Check they are all present and correct.
K2-K6
Reply #18 on:
July 27, 2021, 02:16:25 PM »
Is something stray more likely to enter that area via the drive chain ?
Anything missing near the chain etc ?
gtmdriver
SOHC Expert
Reply #19 on:
July 29, 2021, 07:55:08 AM »
Other side of the bike. The clutch is on the O/S of the bike. There will be further investigation of it's origin.
CB350/400
