SOHC.co.uk Forums > CB350/400
Routing the four float bowl drain pipes...
Athame57:
--- Quote from: Deano400 on August 23, 2021, 10:38:33 AM ---The two clips in the picture are for the battery breather tube (right) and the air filter drain pipe (left). The carb overflow and vent pipes thread between the crank cases and swing arm. The air manifold breather threads through the hole at the rear of the crank cases.
--- End quote ---
Thanks for this Dean, that is really useful, pdf saved. I can't remember when I last had a breather on my battery, is it important?
billdn:
If you're using a gel type battery, eg MotoBatt -then no drain pipe required , but if a conventional wet battery then would be advisable as if the battery boils up , you don't want that on the frame or exhaust chrome- voice of experience there!
Laverda Dave:
Thanks Deano, very useful bit of info. I don't have a battery breather tube. At least re-routing the carb overflows using the correct location will help to identify the leaking carb!!!
Deano400:
Another routing document I have that relates more to cables. Might be useful to some.
ka-ja:
The 4 overflow pipes are held together in a small square plastic former? and drop down in front of the swinging arm.
Navigation
[0] Message Index
[*] Previous page
Go to full version
