Author Topic: Sump Oil Strainer unit  (Read 4153 times)
« on: August 24, 2021, 10:59:55 AM »
I can see loads of muck on the insides of the oil strainer unit - if I attempt to remove the plastic type ring around the guaze will it all break or are they made to be dismantled ?
.sump strainer by Macabe Thiele, on Flickr
Re: Sump Oil Strainer unit
« Reply #1 on: August 24, 2021, 11:53:19 AM »
I don't think they can be dismantled.  Just wash it through from the outside of the mesh , then let it dry before using.
« Reply #2 on: August 24, 2021, 01:26:50 PM »
They do come apart and the strainer and the body are separate part numbers. But, you most often wreck the strainer when trying to get them apart.
« Reply #3 on: August 24, 2021, 03:17:47 PM »
I do not like the look of the muck on the inside funnel shaped part of the striiner might check availablity befor I wreck it?
DS show it as discontinued - might try a bottle brush from the inside with some petrol.
« Last Edit: August 24, 2021, 03:21:21 PM by Macabethiele (Ted) »
« Reply #4 on: August 24, 2021, 03:21:45 PM »
I've got a spare one if you do wreck it. Spray some degreaser or paraffin down it to loosen things up, then
wash it through.
« Reply #5 on: August 24, 2021, 03:24:50 PM »
No longer available Ted, either from DS or CMS.
I always soak ours in the parts wash for a few days, rince out thoroughly with parts wasb fluid or diesel and repeat. They always come up nice and clean.
« Reply #6 on: August 24, 2021, 03:44:06 PM »
I'll do that Julie just tried a quick petrol wash and it went black immediately so clearly needs a good soak in parts wash - petrol is a bit harsh on the rubber part.
Offline Athame57
    • SeaWitch Artist
« Reply #7 on: August 24, 2021, 08:46:10 PM »
Faced with their imminent extinction  :o and if no pattern part emerges to fill the void, can more frequent oil changes be enough to cope with not having one at all?
I brake for animals!
1978 CB400F2 named Elen.
« Reply #8 on: August 24, 2021, 10:56:19 PM »
Aeroslo brake cleaner
Offline Athame57
    • SeaWitch Artist
« Reply #9 on: August 24, 2021, 11:49:34 PM »
Sorry....I don't understand!  ;D
« Reply #10 on: August 25, 2021, 06:45:00 AM »
Get a can of spare-on brake cleaner. That blasts most muck off.
[Bryan Jones translation service].
Offline Charlie J
« Reply #11 on: August 25, 2021, 07:16:42 AM »
I think he means "spray on" brake cleaner
[SteveD translation service].   8)
Offline Charlie J
« Reply #12 on: August 25, 2021, 07:34:37 AM »
Sorry Steve, I just couldn't resist doing that  :) :)
« Reply #13 on: August 25, 2021, 08:00:28 AM »
Hoist by my own …
« Reply #14 on: August 25, 2021, 08:39:00 AM »
I keep telling you my keyboard is dyslexic
