Author Topic: 8 Green "O" rings but where do they go?  (Read 2163 times)
« on: September 01, 2021, 05:40:14 PM »
The gasket set that came with my bike has a nice bag of rubber type "O" ring seals but I am a tad confused about the eight green ones.
The manual shows them under the valve guides (with nice valve seals for the inlets) but I can't see where the green ones go unless they are fitted in place when the guides are pressed in.
So is that where  they go please?
Gasket set seals by Macabe Thiele, on Flickr
« Last Edit: September 01, 2021, 06:00:18 PM by Macabethiele (Ted) »
Offline Athame57
    • SeaWitch Artist
Re: 8 Green "O" rings but where do they go?
« Reply #1 on: September 01, 2021, 06:15:59 PM »
I wonder it they are tappet inspection cover O rings....are they big enough?
« Last Edit: September 01, 2021, 06:18:24 PM by Athame57 »
I brake for animals!
1978 CB400F2 named Elen.
« Reply #2 on: September 01, 2021, 06:45:24 PM »
There are a set of those not in the pictur much larger.
The green things are about 12 mm in diameter.
« Reply #3 on: September 01, 2021, 06:47:51 PM »
They are silicone O rings for under the valve guides. You only fit them if you have new guides inserted.
« Reply #4 on: September 01, 2021, 07:22:08 PM »
Wow that's a very thorough design - usually an interference fit is enough to keep the oil out.
