Author Topic: Cam chain guides question?  (Read 2363 times)
« on: September 20, 2021, 11:15:46 PM »
When is it best to fit the cam chain guides, before you fit the cylinder head or afterwards?
In NJ's rebuild they appear to be in place before fitting the cylinder head - I guess it's easier to put them in position at this stage as presumably you can use a torch to ensure they are fitted correctly at the bottom end?.
Re: Cam chain guides question?
« Reply #1 on: September 21, 2021, 12:31:21 AM »
You might get the tensioner in after head on but you wont get the guide in after head on
« Reply #2 on: September 21, 2021, 08:29:21 AM »
Thanks Bryan - I had it in my mind that one came out when I was stripping down the engine with the head in place - clearly I'll get both in situ before I fit the head.
Offline ttr400
    • CB400F special machined parts
« Reply #3 on: September 21, 2021, 06:25:02 PM »
On the 400 you can install the guide after the head is on.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
