Struggling with clutch adjustment
Topic: Struggling with clutch adjustment (Read 5275 times)
October 06, 2021, 07:31:28 PM »
I'm in the garage trying to adjust the clutch. As a starting point, can anyone tell me .. should all the 4 bolts that hold the clutch / basket be fully screwed in? I've been searching round for inspiration and I think they should be, but when they are I can't disengage the engine/ drive chain.
It seems unlikely that the push rod is too short, and I'm out of adjustment on the lever / cable so I assume my setup is wrong somewhere. Only options i rethink of are that the bolts have pushed the whole lot in too far, or maybe I have the wrong cable with too much freeplay/cable.
Any thoughts appreciated!
McCabe-Thiele (Ted)
Re: Struggling with clutch adjustment
October 06, 2021, 08:58:30 PM »
I'm pretty sure the clutch basket springs should be torqued up. Not sure what your model has in terms of the mechanical system that converts the cable pull into depressing the clutch the 400 has this triple balled plate system. Then if course there might be the thrust movement between the basket & the gearbox shaft. Others here will advise I'm sure.
Link to my full restoration
October 06, 2021, 09:37:06 PM »
Cant tell you how to adjust it till you tell us what bike, and model, it is
Sesman
October 07, 2021, 07:37:17 AM »
High Andy.
Assuming you have a 550, as that’s the forum section this appears in, all four screws should be tightened down to the specified torque. Are you sure the clutch housing lever is on the correct side of the lever mechanism. If the bike has been stripped down it’s easy to over extend the lever and have it flop to the wrong side of the operating mechanism in the housing. That’s only one possible cause of course.
October 07, 2021, 07:50:51 AM »
Thanks for the thoughts....model is a 550F2.
The mechanism inside has been set up so it doesn't flop about - and the cam stays behind the actuating arm and is pushed back into place when the clutch lever is released, so I'm sure
I'll dig out the torque settings and check those.
Cable is new and I can't find a receipt but I'm sure it's right but if not and it's too long, potentially could that mean it doesn't disengage enough.
Plus it's an old clutch so could the plates be too thin..but then it would slip rather than grip...
I'll check the torque first and report back.
paul G
October 07, 2021, 07:56:28 AM »
Another issue could be that the teeth on the basket and pressure plate that hold the friction plates are not aligned correctly.
I did this on the 750 and when the pressure plate is tightened down it locks the clutch instead of lining up with the groves on the basket.
I would re-check this first.
deltarider
My kingdom for a turkey!
October 07, 2021, 08:17:55 AM »
Warning
. I've once torqued the 4 bolts on my CB500's clutch. Every time I followed the manual and torqued at the prescribed value, the heads snapped of. No exception. Ever since I have used my senses, which can be accurate and... no problem.
Sesman
October 07, 2021, 08:22:26 AM »
I also own an F2 (the fastest model)
. I’ll be assembling my clutch this weekend, so I’ll report back if I encounter any problems.
October 07, 2021, 09:07:07 AM »
I've seen a number of comments about the torque values and snapping old bolts so I'll be very wary and work on pinching them up plus maybe a quarter turn. Seems that subject to torque settings, the bolts are all the way in and since that's what I had previously then there must be something else I've not picked up yet.
Will check alignment too - they are old plates so they've been removed, unstuck and replaced so I'm fairly sure they are OK but it's all worth rechecking.
Sesman
October 07, 2021, 09:22:31 AM »
I didn’t register a torque setting for this bolts, so I went for 6ftlbs and left it at that. Basically turned them until they ‘shouldered’ and another half turn. About as tight as I’ve ever tightened a 6mm bolt and I’ve never had a problem.
deltarider
Reply #10 on:
October 07, 2021, 10:32:39 AM »
Could be I did it wrong and one should yield the springs first, although I don't see how
that
is done.
Anyway, I always follow my uncle's (a mechanic) advice: stop just before it snaps.
If you're lucky you may end up with bolts that look as eager as these Karen girls.
