Author Topic: 500 gearbox bearing  (Read 4455 times)
Offline oldboy
500 gearbox bearing
« on: October 21, 2021, 05:47:23 PM »
Anybody know of any bearing factors that can supply gearbox sprocket bearings for a 500, or is it pay through the nose for the genuine item??
Re: 500 gearbox bearing
« Reply #1 on: October 21, 2021, 07:14:39 PM »
If you are talking about part number 91002-286-008, I have a couple in stock at the moment.
Offline oldboy
« Reply #2 on: October 21, 2021, 07:27:35 PM »
Thanks for the reply, unfortunately it's the other side 91002 283 003, but depending on price I could replace both as it would be in bits anyway!!
« Reply #3 on: October 21, 2021, 07:30:03 PM »
Is that theone with the circlip groove? If so you are stuck with genuine i think
« Reply #4 on: October 21, 2021, 07:31:17 PM »
They both have circlip grooves Bryan.
« Reply #5 on: October 21, 2021, 07:36:20 PM »
I will get Graham to look at a 500 gearbox tomorrow to see if we can work out if we have the one you need in stock. I'll get back to you tomorrow evening. I do know that these grooved bearings are getting to be a nightmare to source, genuine or otherwise. I know all our usual suppliers haven't got stock.
« Last Edit: October 21, 2021, 07:39:09 PM by Nurse Julie »
Offline oldboy
« Reply #6 on: October 21, 2021, 07:44:07 PM »
Many thanks, appreciate you help.
« Reply #7 on: October 23, 2021, 09:43:02 AM »
Sorry for the delay in replying. Unfortunately we do not have the bearing you need in stock.
Offline oldboy
« Reply #8 on: October 23, 2021, 12:27:32 PM »
Thanks very much for looking.
Offline oldboy
« Reply #9 on: October 24, 2021, 07:45:35 PM »
I'm thinking it's on it's way as there seems to be quite a whining from that side when under load, could be the bearing or a worn gear. It's not the chain as the noise goes when you pull the clutch in and freewheel. I would like a bearing in my hand before stripping the motor and finding that none are available. There are some out in Germany at silly money plus silly postage. A very last resort.!!
