Author Topic: Tank derust advice please.  (Read 10919 times)
Offline Charlie J
Re: Tank derust advice please.
« Reply #30 on: November 04, 2021, 08:34:36 PM »
Did mine a couple of weeks ago using a 10:1 ratio of water and oxcalic acid left to soak for 24 hours, then rinsed with water for 10 minutes, dried with hot air gun, followed by swilling with 2 stroke oil and a splash of petrol.  The process removed some fairly heavy rust and no problem with flash rusting.
Offline ST1100
« Reply #31 on: November 05, 2021, 11:33:54 AM »
Your English is extremely good no trace of an accent...
Thanx Ted!  8)
Being present on motorcycle related email-lists and forums since the 90ies...
Deciphering British humor however provides occasional challenges though...  ;D
I had to give the heavily corroded CX500E tank out the house, they cleaned the goo out with (industrial grade) hot (120°C) high-pressure wash, then some acids, neutralizers, oven drying (60°C), finally a POR-15 treatment as the surfaces and especially the seams were in really bad shape... fortunately no leaks...
STOC #637
« Reply #32 on: November 06, 2021, 09:22:25 PM »
Ok, it worked. ;D ;D ;D
Absolutely spotless.
Offline murdock
« Reply #33 on: November 06, 2021, 09:53:29 PM »
TO DO IS TO KILL THE RUST, LEAVE IT FOR 2 DAYS WITH VINEGAR AND THEN AN OXIDE CONVERTER BASED ON PHOSPHORIC ACID, THEN YOU MUST PAINT IT INSIDE WITH HYDROCARBON RESISTANT RESIN, IF YOU WANT MORE INFORMATION I CAN GIVE YOU LINKS
