Project Board
The rebirth of Lazarus
24
25
26
27
29
Topic: The rebirth of Lazarus (Read 224449 times)
mickwinf
Re: The rebirth of Lazarus
Reply #360 on:
March 04, 2024, 12:55:01 PM »
I tried to check rectifier but not getting any readings, I do have a spare so will try that one. I hate electrics!
taysidedragon
Reply #361 on:
March 04, 2024, 01:03:21 PM »
Mick, if that doesn't do the trick do you have any electrical wizard mates nearby who can help?
royhall
Keep biking I'm not quite bankrupt yet
Reply #362 on:
March 04, 2024, 02:01:49 PM »
Are you by any chance using a fully charged AGM battery. If you are, the charging probably won't cut in until the battery gets down to about 12.4 volts. Makes it look like the charging isn't working. There's a way of testing that explained in my CB750K5 restoration thread. Spent a whole day on mine pulling everything apart just to find there was nothing wrong in the first place.
Last Edit: March 04, 2024, 02:03:35 PM by royhall
mickwinf
Reply #363 on:
March 04, 2024, 03:34:16 PM »
hi Roy its a yuasa normal lead acid type battery. I am now looking for an idiots guide to using a multimeter, watch this space.
Reply #364 on:
March 04, 2024, 03:51:53 PM »
Mick, if you can wait till thurzday night (after
you can ring me on 07795162623 and i will explain it to you, especially if you have the rec and meter in your hands
That should read after 8, i hate dumfones!!!!!!
Last Edit: March 04, 2024, 04:46:52 PM by Bryanj
royhall
Reply #365 on:
March 04, 2024, 04:34:57 PM »
It will still happen if your battery is fully charged even on a lead acid type.
Sent from my Pixel 7 Pro using Tapatalk
mickwinf
Reply #366 on:
March 04, 2024, 05:19:12 PM »
Thanks Bryan might take you up on that. Some progress with the rectifier, I didn't realise if it didn't read one way round one way try the other way round. This shows now as ok.
mickwinf
Reply #367 on:
March 06, 2024, 10:56:46 PM »
Looking again at alternator, the original one that came with the bike and the wires had been cut so put terminals on and extended wires to proper connector block. Thing is I dont get any readings at all at the multi connector but if i disconnect the wires at the joints I do get a result so maybe a faulty wire? The only spare I have also has the wires cut so no better. More investigation needed.
Reply #368 on:
March 06, 2024, 11:29:16 PM »
Did you scrape the varnish off the windings wire before you soldered?
mickwinf
Reply #369 on:
March 07, 2024, 08:47:45 AM »
I joined the wires under the sprocket cover
Reply #370 on:
March 07, 2024, 11:32:30 AM »
Go to Ash's emporium and look up the 3 phase charging system document that explains how the whole system works, plus ring me tonight and i will give you some testing to do
mickwinf
Reply #371 on:
March 09, 2024, 01:14:39 PM »
This morning I rechecked the connections and found a bad contact, sorted that then checked the voltage regulator which turned out to be ok, even tried a spare with no luck. the battery seems to hover around 11.5 volts when engine is running and does not increase with revs. rectifier tests out ok, again tried a spare with no change. not sure what to do next, any ideas?
McCabe-Thiele (Ted)
Reply #372 on:
March 09, 2024, 01:36:56 PM »
What is the voltage across the battery terminals with the ignition off?
Looks as if the alternator is not putting out any charge for it to drop to 11.5 volts when running.
I know now't about testing the alternator itself even after I have read the manual. In my case Impedence is a measure of my Ignorance.
Addendum:
I have had experience of electrical windings as in the coils/field windings absorbing damp and even recovering over time as they dry out. I know it's the often repeated mantra but good earthing & good electrical connections are a must.
Last Edit: March 09, 2024, 01:40:37 PM by McCabe-Thiele (Ted)
Link to my full restoration
Seabeowner
Reply #373 on:
March 09, 2024, 07:04:28 PM »
I've been lucky and all my rebuilds have charged fine. But your problem is not uncommon.
The goto in the US is Twotired.
Link to his post.
http://forums.sohc4.net/index.php?topic=118474.0
1971 CB500K0 Candy Jade Green or Candy Gold
1973 CB500K1 Candy Ruby Red
1975 CB550F1 Shiny Orange
Reply #374 on:
March 09, 2024, 09:01:43 PM »
I am at work now and tomorrow night if you want to ring, after that not till next friday
24
25
26
27
29
Project Board
