Author Topic: Tank trim  (Read 2506 times)
Tank trim
« on: November 07, 2021, 09:58:00 AM »
I cleansed my tank recently, but my liberal use of WD40 to protect the paintwork has done great job to release whatever product was securing the tank trim. Is there a preferred product to reattach the trim, or is replacement trim supplied with an adhesive activated in hot water?
Re: Tank trim
« Reply #1 on: November 07, 2021, 12:09:39 PM »
Depends what trim you are using Phil. The type I supply has self adhesive strip fitted, so you just push the trim on and it stays there.
Re: Tank trim
« Reply #2 on: November 07, 2021, 02:15:05 PM »
Thanks all. I’ll try silicon and if fails, Order from Julie.
Re: Tank trim
« Reply #3 on: November 07, 2021, 04:01:45 PM »
Top tip. Cheers.
