Author Topic: 550 F2 started!  (Read 345969 times)
Online Oddjob
Re: 550 F2 started!
« Reply #615 on: October 27, 2022, 08:23:25 PM »
Only one sprocket carrier in that pic Roo, bottom right. Same as 500 though. The chain guard is also the same. The hub is different from the 500 as is the brake plate and the sprocket spacer and the rear brake spacer.
The brake plate on the left looks like a 550F one Roo, in case you need one.
Re: 550 F2 started!
« Reply #616 on: October 27, 2022, 08:44:17 PM »
I'm buying that one you refer to.  I thought I had one in the bundle of gubbins I bought  but it appears to be for a 500 and obviously wont fit. Hence the shout to Gary to see what he had.
Re: 550 F2 started!
« Reply #617 on: October 28, 2022, 01:27:41 AM »
Right, so clutch question,
In the middle of the steels there is a big, fat ,almost double steel as indicated on the parts diagram but on all the vidoes I've seen of replacing these cltcheson the 550,  they dont have them, is that because mine's and F2 and not a K?
It's not very clear from the parts manual as to whats what but if I reassemble in the order it came out I should be right? Right?
I diidnt take much notice upon taking it apart as it came out as one, glued together lump which was hastily zipped up in a bag and put in the nanny pile. It' only upon starting on that side of the motor I saw it and had to have a gander at the parts book.
Not seen one of these thick jobs before, whats the crack there then?
I'm sorted with the one big tooothed friction plate just not seen one of these before.
Re: 550 F2 started!
« Reply #618 on: October 28, 2022, 04:07:28 AM »
Its there to try and stop clutch rattle, actually a gl1000 part. The top fibre plate should have wider "tangs" to fit in wider grooves in the basket. Later clutches are like it
Re: 550 F2 started!
« Reply #619 on: October 28, 2022, 09:35:55 AM »
Thanks Bryan,
Yes I know about the wider tangs and its position, just not seen one of these before and watching a lot of how to vids and the like, I haven't seen anybody else with one in their clutch set up. Just got me interested enough to ask the question. Thanks Bryan.
Re: 550 F2 started!
« Reply #620 on: October 29, 2022, 01:32:44 AM »
Could anybody point me in the right direction of a good JIS screw supplier for the engine covers or should I be asking Julie?
A complete set preferably.
Not into the Allen key type so after a nice shiny set of the JIS ones.
Phanks in advance
Offline SPR
  • 1972 500/4 K1
Re: 550 F2 started!
« Reply #621 on: October 29, 2022, 07:31:40 AM »
Re: 550 F2 started!
« Reply #622 on: October 29, 2022, 07:40:21 AM »
I think Silvers does cover sets
Re: 550 F2 started!
« Reply #623 on: October 29, 2022, 12:47:06 PM »
Sorted, thanks chaps 8)
Re: 550 F2 started!
« Reply #624 on: October 31, 2022, 03:00:50 AM »
Interesting cleaning tonight, just getting bagged bits sorted for fitting and some I left in their own grease to be fettled prior to fitting.
I’m starting to sort the twin disc conversion sorted now I’ve got my rims back and was cleaning the drive gear from the front hub and found that the previous owner had kindly run a razor blade round the centre!
Why on earth would anybody do that. It now means I’m on the hunt fir one of these now. I’ve found one in the states typically and one in Japan. I’ll have to bob up a desperately seeking but if anyones got one could I relieve you of it?
Re: 550 F2 started!
« Reply #625 on: October 31, 2022, 03:01:33 AM »
Number 8
Re: 550 F2 started!
« Reply #626 on: October 31, 2022, 03:02:52 AM »
Online Oddjob
Re: 550 F2 started!
« Reply #627 on: October 31, 2022, 09:35:59 AM »
I had one but gave it to Sesman for his twin conversion.
Re: 550 F2 started!
« Reply #628 on: October 31, 2022, 09:45:18 AM »
You dont want one of the originals for a twin disc, it needs modifying, email me or ring me tonight or tomorrow(away after that)
Re: 550 F2 started!
« Reply #629 on: October 31, 2022, 10:56:51 AM »
will do Bryan, cheers mate.
