Author Topic: Engine case paint  (Read 11991 times)
Offline sim2011
  • CB750 K3
Engine case paint
« on: April 05, 2010, 08:20:09 AM »
Hi everyone
Has any one used this paint on their barrells head and casings ? SIMONIZ VHT SILVER SPRAY PAINT RATED TO 650 degrees C , 1200 degrees F , if so
A/ is the colour right ?
B/ is it any good ?
Simon CB750K3
Current Bikes            Previous Bikes
Honda CB750K3           Ducati 748R               Suzuki GSXR 750J Slingshot
Suzuki GT550M           Ducati 900 Superlight   Honda CB985F
Suzuki GT250B            Suzuki GSXR 750M      Honda CB900F
                               Honda CB750F1           Honda CB250G5
                               Suzuki GT250B            Suzuki B120
Offline pae
    • Phil's CB650 pages
Re: Engine case paint
« Reply #1 on: April 05, 2010, 09:19:34 AM »
Hi, I used this...
applied really easily, dries fast, doesn't run, and looks good. So far it's lasted well as long as you prep it well (ain't that always the case?)
Offline UK Pete
« Reply #2 on: April 05, 2010, 09:34:48 AM »
Hi Simon i am using por15 engine paint, but i have never tried it before , it seems many people use the silver wheel paint for the colour match i am not sure about heat resistance in the long run but its certainly popular.
Hi PAE i have never seen a detachable lower frame tube before is it a home made thing?
Pete
Offline sim2011
  • CB750 K3
« Reply #3 on: April 05, 2010, 03:39:10 PM »
Hi Thanks for the advice, now I seem to rember that My F1 had a detchable frame part but is was 30 + years ago !
I wonder what the colour differnce is between Simoniz 5 Wheel Silver and Simoniz Silver VHT
Simon
« Reply #4 on: April 05, 2010, 05:43:07 PM »
Pete - I think the detachable frame rail is a a CB650 thing.
Offline pae
« Reply #5 on: April 05, 2010, 05:46:05 PM »
Pete
No, as Andy120t says, it's a 650 thing. Damn good idea too.
Online SteveD CB500K0
« Reply #6 on: April 05, 2010, 05:55:20 PM »
I'm sure there's a guy on sohc.net who modified his 750 to a detachable rail.
Offline the-chauffeur
« Reply #7 on: April 05, 2010, 09:15:08 PM »
Yup, it's one of the five or so different types of paint I've used.
The second question - is it any good - is much harder to answer.  Yes insofar as it's silver, heatproof and about the right colour for the 750 engine cases.  But - and it's a big but - even after I had the paint on my cases heat treated, it still isn't what I would call properly petrol-proof.  That said, none of the other paints I've used (inc. POR15 and some really hardcore stuff from Frosts) has been petrol-proof - and I think I've tried just about everything including solvent cleaning and bead blasting the cases before painting.
Having said that, the biggest area you need to worry about is the bottom end cases - the barrels/head are subjected to high temperatures pretty much all the time, so the paint seems quite hardy and stable on those areas (and as they're nowhere near the carbs, they tend to stay out of the way of petrol leaks).  The lower cases never really get very hot, and sit directly under the carbs, so the potential for disaster is quite high - the paint ran on the last set I did when one of the carbs leaked.  Consequently, although the stuff isn't heat proof, I reckon petrol resistant lacquer is the way to go on those lower cases.
Three other things I haven't tried - yet.  One is the wheel paint shown above.  The second is priming the bits with heat-resistant etch primer (if there is such a thing).  A third is two pack paint/lacquer.
Offline sim2011
  • CB750 K3
« Reply #8 on: April 06, 2010, 09:17:04 PM »
Thx
I might try the Silver Simoniz VHT and also their petrol proof laquer
Simon
Offline honda-san
« Reply #9 on: April 06, 2010, 09:48:24 PM »
My ' 69 was painted with 5 wheel silver back in '94 when it was PROPER paint (you know, cellulose based and going to kill the planet). Colour was good, definately petrol resistant, and after 80,000 miles is still firmly attached and has not yellowed.
Sadly the modern Simoniz equivalent is not petrol proof the same. Like most things in modern life. New /  improved, but not a step forward in practical terms. Only way to work out whats best is to try them out on a test piece of some kind, cure in an oven at say 100
Chris R.
Offline sim2011
  • CB750 K3
« Reply #10 on: April 06, 2010, 11:08:06 PM »
Will do
I've got plenty of time , not looking to strip or paint the motor until after the summer , I'll buy some simoniz and spary on some old ally casings I've got
Watch this space.
Simon
