Other Stuff
Misc / Open
Plastic throttle tube.
Topic: Plastic throttle tube. (Read 2046 times)
Johnny4428
December 21, 2021, 11:45:13 AM »
Quick question! Lube or no lube? Maybe a little on the cable end but not on the bars? I’ve not had any bother in the past but just wondered about the correct or recommended application.
taysidedragon
Re: Plastic throttle tube.
December 21, 2021, 12:13:11 PM »
I've always put a smear of light oil on the bar, not sure if it's necessary, but never caused a problem.
Oddjob
December 21, 2021, 01:06:04 PM »
Always lube the bars myself. Usually silicon grease or oil.
McCabe-Thiele (Ted)
December 21, 2021, 06:18:58 PM »
I used Silicone Spray lubricant after thorough cleaning.
I use silicone spray instead of grease on my garage door mechanism as it does seem to attract the dirt & clog like normal oils & grease.
Last Edit: December 21, 2021, 06:22:32 PM by McCabe-Thiele (Ted)
Link to my full restoration
Johnny4428
December 21, 2021, 10:50:44 PM »
Thanks guys, I have fitted using silicon spray on bar and lithium grease on cable end of tube.
Other Stuff
Misc / Open
