CB750
Not so much a Problem but.........
Topic: Not so much a Problem but......... (Read 5997 times)
PMK
SOHC Member
Destroyer of Fine Motorcycles & Idiot for Hire
April 11, 2010, 06:44:06 PM »
How many miles should expect from an F2 tank.
On a couple of good long motorway and dual carriageway runs I'm hitting reserve at 113 miles. This seems too little to me as I'm not ragging her, nothing more than 6,000 rpm.
I would have thought that 150 to reserve would be more what I would expect.
Over to the experts
He who breaks something to see how it works has left the path of wisdom and become an engineer
Honda CB750F2 1978
Harley Sportster 883 1999
Matchless G80 1960
mick
Re: Not so much a Problem but.........
April 11, 2010, 06:49:09 PM »
Hi, sounds about right to me my F1 does somewhere round that to a tank full maybe a bit more or less depending how i ride it
, cheers Mick.
honda-san
SOHC Associate
April 11, 2010, 08:33:21 PM »
Usually my F2 runs between 150 and 160 to reserve. I tend to cruise around about 6000 rpm wherever possible too, but often "use it all" under acceleration (non standard silencer - sounds great
Working it out over several tank fulls, it generally averages approx 50mpg (11 miles per litre if you prefer)
113 does not sound much to me! Air filter clean / newish?
Chris R.
PMK
SOHC Member
April 11, 2010, 09:53:50 PM »
Yep!! and it's stock.
It doesn't like a lot of choke so I was thinking of diddling with the mixture screws. To check the set up are they the screws at the front of the carb under the inlet rubber?
To just recap everything else is o.k, you know tappets etc.
Possibly it may jets that are too big but I'll cross that afterwards
Honda CB750F2 1978
Matchless G80 1960
Yoshi823
Biker to the bone...
April 11, 2010, 10:28:46 PM »
When my 750 was standard I can remember getting about 120 miles before reserve...but wasn't 6000 rpm about 80 mph? on standard gearing?
At one time I tried one of these
http://www.unifilter.com/online%20catalog/streethonda.html
as a standard replacement air filter, but when the modifications started the airbox was one of the first things to go.
The air screws are at the very front of the float bowl mounting & should be 1.75 turns out. But I would check that the needles have the clip in the middle position & that the float heights are correct (sorry-I cannot remember off-hand what this should be). All of these will have an effect on fuel consumption, as will gearing & the condition of sparl plugs, chains, sprockets, ignition coil voltage output etc etc.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
F2 Paul 876
SOHC Associate
April 12, 2010, 12:18:42 AM »
Hi I got about 120 ish before i hit res most of the time on my F2 so sounds about ok to me.
Float Level is 14.5 mm (0.5709 in) Idle is 1.000 +or - 100rpm Fast Idle 2750 + or - 750 rpm
Main Jet #105 Slow Jet #35 Main Air Jet #120 Slow Air Jet #150 Jet Needle Setting F2051F-2
Pilot Screw 1 3/4 turns. Hope this helps.
Passed Bikes
CB 250 G5
CB 550 K3
CX 500 B2
VT 500 E X2
Still got
CB750 F2 2 off 1 Rebuilding 1 Waiting Rebuild
PMK
SOHC Member
April 12, 2010, 12:32:43 PM »
Ta chaps all useful stuff
Honda CB750F2 1978
Matchless G80 1960
Spitfire
April 12, 2010, 12:37:39 PM »
Just realised the T Shirt looks just like the Logo for Dick Smith electronic shops in Oz, just changed the secondword !
Den
PMK
SOHC Member
April 12, 2010, 02:52:17 PM »
Yep
I bought it Thailand a few years ago.
Nothing like broadcasting the truth
Honda CB750F2 1978
Matchless G80 1960
CB750
