Author Topic: Compression test results  (Read 2838 times)
watty51
« on: February 01, 2022, 08:25:38 PM »
Hi all,
Just fitted new piston rings, refreshed all the engine gaskets etc, and thought while I was waiting for a new battery to be delivered I thought I would do a cold compression test.
No spark plugs in.
Full open throttle.
All carbs and air cleaner attached.
No battery so used the kick stater.
Think the results seem promising. Cylinder 1 155psi. Cylinder 2 150psi Cylinder 3 155 psi Cylinder 4 160psi
The compression on a warm cylinder according to the manual is 170 psi
Does a cold test give accurate readings or will the true condition of the engine compression only be found when a warm test is Carried out.
Ta Mark
Re: Compression test results
« Reply #1 on: February 01, 2022, 08:48:00 PM »
You won't get an accurate compression reading until the new piston rings have bedded in. Your readings at the moment sound fine to me.
« Reply #2 on: February 01, 2022, 08:56:08 PM »
Not a bad result for new rings and cold. Should increase when hot as things expand and start to seal up better.
« Reply #3 on: February 02, 2022, 08:44:33 PM »
Look like good readings to me as well - if it starts easily from cold as well great. As has been said they will improve as the rings bed in.
