Author Topic: Stripped oil passage cap on bottom end. Solutions?  (Read 7708 times)
Offline alexdecker
« on: February 13, 2022, 12:30:20 PM »
Alright, so this bugger striped in the very first try of unscrewing it. Any advice?
Re: Stripped oil passage cap on bottom end. Solutions?
« Reply #1 on: February 13, 2022, 12:57:22 PM »
Stiltsons and replace it
Offline alexdecker
« Reply #2 on: February 13, 2022, 01:04:01 PM »
*Sigh*
The sheer amount of excessive force required to take an engine apart is mind-boggling! Thought the process would be a little more finessed.
Hopefully putting it back together again will offer the finesse I am longing for…
« Reply #3 on: February 13, 2022, 01:05:19 PM »
Sorry, but did you say “Stripped”, as in the thread stripped.
« Reply #4 on: February 13, 2022, 01:08:34 PM »
Or just a rounded cap head? Never known one strip, but deffo had to destroy a few getting them out. I have in the past reclaimed them, filing the flats to the next size socket. But it’s a tedious and unrewarding exercise and I’d be inclined to just replace it.
Offline alexdecker
« Reply #5 on: February 13, 2022, 01:40:53 PM »
Rounded of course. Sorry bout that 😊
Offline Phil Ward (RIP)
« Reply #6 on: February 13, 2022, 01:50:29 PM »
I ALWAYS use 6 point spanners/sockets on these alloy nuts. Same with tappet cover. 6 point spanner, take up any slight slack and tap spanner end with hammer.
« Reply #7 on: February 13, 2022, 02:39:22 PM »
Had to remove all 3 just last week, 6 pointed impact socket and a decent impact driver got them out no problem but they were tight.
That nut is now wrecked so try this, sharp edged cold chisel, cut a slot at 3 o’clock, not the time, the location, angle the chisel and hammer into the slot so it drives the nut round not down. Works nine times out of ten.
It’s an old mechanics trick for when a nut rounded off.
« Reply #8 on: February 13, 2022, 07:40:01 PM »
Used that method many times back in the 70's Ken - my old school engineer dad taught me!
Offline murdock
« Reply #9 on: February 13, 2022, 08:31:14 PM »
cortalo al medio con cuidado para no tocar la caja con una amoladora o una dremel . luego con la stiltson saldra facil
cut it in the middle with a grinder or a dremel. then with the stiltson it will come out easy.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #10 on: February 14, 2022, 09:47:19 AM »
+ the above, I remove my 400/4 seized one using a die grinder cutter to remove the head and "groove" it internally, then collapsed it in and off the thread, luckily, I had a tap that cleared the threads afterwards
nice bike,nothing in the bank
« Reply #11 on: February 14, 2022, 10:20:42 AM »
You should never try to remove these with a impact driver as, these are thin alloy and can crack. I must of removed thousands of these over the years. The early 750 had a 17mm head which was easy to remove then, Honda changed them to a 14mm head making, them more difficult to get a grip on.
Heat the around the cap to 250 degrees to soften the o'ring  and break the seal and use a metrinch socket which grips the flats ;)
« Reply #12 on: February 14, 2022, 10:57:28 AM »
Agree with this,  trying to conserve the original method of turning anything is primary in getting them undone for many design.
Going straight to cutting or damaging as a strategy is often limited in my view. From a engineering workshop perspective in trying to recover broken, damaged, or otherwise impaired fixings, it's often not without compromise. The right decision first will help keep you away from some limitations in practical engineering solutions and avoid needing replacement ultimately.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #13 on: February 14, 2022, 07:07:17 PM »
Not forgetting that any form of turning a seized gallery cap will cause further damage if it is the threads that are seized and not the o-ring surfaces
« Reply #14 on: February 14, 2022, 08:28:47 PM »
That's unusual as the design on most I can think of have the threads inside the oil gallery (the internal side of o-ring) with the ring sealing those from atmosphere and contamination. Clever those Japanese  :)
