Author Topic: 500/550 Rear Hub D ring 79mm x 2.6mm (91261-323-000)  (Read 4200 times)
Offline Erny
  • CB750K7 CB550K1
« on: February 14, 2022, 08:27:44 AM »
Just have (finally!) my rear hub apart to replace dumper rubbers.
Will also replace bearings (left one has damaged seal), but windering where to get specific D ring that goes between hub body and flange. My old one has 1.85mm instead of 2.6.
Original seems it is nowhere available, just found some aftermarket but it is O ring, not D ring.
How do you manage that on your builds? Not sure if O ring instead of D ring will seal (groove for D ring seems to be wider than for O ring)
D ring is item #50
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline sye
Re: 500/550 Rear Hub D ring 79mm x 2.6mm (91261-323-000)
« Reply #1 on: February 14, 2022, 10:50:38 AM »
May be worth sending these an email?
https://www.barnwell.co.uk/products/d-ring-seals/
Offline deltarider
« Reply #2 on: February 14, 2022, 01:19:29 PM »
Are you sure it is supposed to be a D ring? CMSNL, DS and the Japanese CB500 Parts List suggest it is. All other sources say it's an O-ring.
The pic in the parts lists is not very clear, I'm afraid and you're not the first one that has trouble interpreting it. There could be an error.
I've worked on my drive flange some years ago and IIRC, the large (thin) O-ring goes around the boss and the smaller thicker one is supposed to be on (rather in) the back side of the PLATE, SPROCKET SIDE. I remember mine was a bit squared, but I have no idea if it originally had been so so, or deformed by the groove. Mine sat quite loosely.
« Last Edit: February 14, 2022, 01:45:04 PM by deltarider »
« Reply #3 on: February 14, 2022, 01:46:14 PM »
I was wondering the same D or O ring.
Ordinarily the groove form controls the "in use" shape.
The rocker gasket for example might have two square form grooves for the O-ring to deform into and allow the two metal faces to meet completely. If it doesn't have those two unused corners for the ring to expand towards you can't close the joint completely.
Compared to a groove with a semi circular form that Forces the O-ring to hold it's shape and give extension to it's uncontained side such that it seals lightly with the other metal component and helps prevent the two touching while giving a dust seal.
It's all in the detail  :)
Offline deltarider
« Reply #4 on: February 14, 2022, 01:54:39 PM »
IIRC, back then I've concluded that the pic was wrong and that #50 should have been named #51 and vice versa.
« Reply #5 on: February 14, 2022, 02:00:32 PM »
Its definitely a D ring, I had some of that part number in a job lot years ago but non left
« Reply #6 on: February 14, 2022, 05:20:13 PM »
Yeah, it's shaped like a D when new.
Offline Erny
  • CB750K7 CB550K1
« Reply #7 on: February 14, 2022, 07:31:00 PM »
It is definitely D shape, groove is unusually wide (to accomodate flat part of ring). I assume it is to better seal as per my googling: "The flat geometry on the base of the D-ring stops the seal from twisting and rolling, preventing spiral failure often seen when O-rings are used in reciprocating applications"
I sent email to banrwell, let's see if they answer something
« Reply #8 on: February 15, 2022, 12:40:44 AM »
If you cant get the D ring i would measure the depth of the groove add a very small amount and call that the x section of the one you want and fit with lots of rubber lube
Offline Erny
  • CB750K7 CB550K1
« Reply #9 on: February 15, 2022, 12:08:09 PM »
Or (just thinking) place a band of thin rubber for example from old thin bicycle tube) under the old D ring, like that make groove shallow and hopefully original D ring will still seal. Will try it if it fits
« Reply #10 on: February 15, 2022, 01:21:26 PM »
You can make a band like that by sanding the two ends to a taper (in thickness) and glueing with puncture repair solution to give a uniform band.
Easiest to do it in a wider band as it's more stable to work with, then cut off a single strip to give the final width you need.
Offline Erny
  • CB750K7 CB550K1
« Reply #11 on: February 15, 2022, 06:48:14 PM »
Update on this topic - I found company which will manufacture D rings up to specification (79x2.6), from NBR material.
Tomorrow I'm going to place order - is there somebody else interested too?
Expected cost is 5-6 euro/pc depending final qty.
Let me know asap if interested
Shipping from Slovakia to UK is normally quite cheap in bubble envelope
« Reply #12 on: February 15, 2022, 07:37:37 PM »
How many do you need to order to get them done Erny?
Put me down for 5 please.
« Reply #13 on: February 15, 2022, 08:43:20 PM »
I’ll take a couple please.
Offline mickwinf
« Reply #14 on: February 15, 2022, 10:51:39 PM »
I would take 2 please
