Author Topic: 3 terminal flasher/winker units.  (Read 3779 times)
« on: March 03, 2022, 06:48:57 PM »
My old 3 terminal flasher unit is a big heap of rust inside so needs replacing - the daft priced DS replacement @£78 has only 2 terminals and is squareish not round,  presumably that means changing the connections somehow.
I have a NOS car unit in my garage that has three terminals marked L P & X am I right in thinking I can use this one as its designed for the same wattage bulbs and is the same diameter as the original?
« Last Edit: March 03, 2022, 06:51:35 PM by McCabe-Thiele (Ted) »
Re: 3 terminal flasher/winker units.
« Reply #1 on: March 03, 2022, 07:51:52 PM »
Just buy a cheap generic 2 pin one off ebay Ted and leave the green, earth, wire unconnected.
Online Oddjob
« Reply #2 on: March 03, 2022, 08:39:52 PM »
OR, ask on the forum in the desperately seeking section for an original relay, you'd be surprised how many there are just lying around unused and cheap.
« Reply #3 on: March 03, 2022, 08:53:19 PM »
And faulty  .. they have electrolyic condensers built into the alloy can that age after 40 'ish years
Online Oddjob
« Reply #4 on: March 03, 2022, 10:16:19 PM »
All mine still work.
« Reply #5 on: March 04, 2022, 08:59:08 AM »
Mine did not work I was stunned when I saw why!
.flasher unit by Macabe Thiele, on Flickr
« Reply #6 on: March 04, 2022, 10:49:23 AM »
Good old liquid sunshne!
« Reply #7 on: March 04, 2022, 01:03:55 PM »
Think it’s done a good job of retaining water.
« Reply #8 on: March 04, 2022, 06:22:38 PM »
I've fitted my car NOS car unit they all work fine!
