Author Topic: Hi from WA, CB400F rebuild  (Read 6455 times)
Offline AndyPerthWA
« on: March 09, 2022, 12:05:54 PM »
Hi everyone, I have just rebuilt my 400-Four which I purchased in Sydney in 1983. She has been across the Nullabor Plain 3 times and now resides in Perth, Western Australia.
having trouble setting up rebuilt carbs, they are leaking out the overflows.
Andy
Re: Hi from WA, CB400F rebuild
« Reply #1 on: March 09, 2022, 12:16:04 PM »
Welcome to the forum, posh garage there  ;D
The carbs can take quite a bit of detailed careful work to get them comfortably working certainly.
Bike looks really good.
Offline AndyPerthWA
« Reply #2 on: March 09, 2022, 12:40:37 PM »
Thanks K2-K6, it's frustrating trying to get her running well without overflowing fuel, I've had the carbs on and off about 20 times!
« Reply #3 on: March 09, 2022, 01:06:05 PM »
Welcome to the forum. We have a few 400/4 owners in Perth hopefully one will pop up soon and say Hi.
« Reply #4 on: March 09, 2022, 02:08:57 PM »
Have you tried polishing the inlet valve seats of the float valve shutoff?  Something like a bbq wood skewer with t-cut (just a gentle abrasive polish) to make sure of competent sealing surface may assist reliable close off.
Either twizzle it with your hands or spin slowly in a drill to give the tapered seat a clean and smooth surface.
Drives you nuts when they keep letting fuel out doesn't it. Seems so simple but fundamental to running well.
Offline Phil Ward (RIP)
« Reply #5 on: March 09, 2022, 09:02:17 PM »
Welcome to the forum. Hope you get the overflowing sorted. Plus 1 on K2-K6's suggestion.
« Reply #6 on: March 10, 2022, 09:24:07 AM »
Welcome to the 400/4 forum :). As anybody will tell you, the yellow ones were the fastest!
I agree with Nigel about the carbs, they are a real pain to set up to avoid leaks. I have found along with many others on the forum that it is best to use the old brassware if you can and cleaned in an ultrasonic bath along with the rest of the carb parts. I have used Keyster carb kits twice and could not stop the leaks so reused the originals and hey presto, no more leaks.
Did you bench sinc the carbs before putting the carb bank back on the bike, worthwhile doing and saves a whole lot of aggro if you do.
Type in 'carbs' to the search box and you'll get a few links to threads all mentioning the same subject.
Offline AndyPerthWA
« Reply #7 on: March 10, 2022, 10:08:13 AM »
Thanks for the welcome Nurse Julie, I will view your posts.
Offline AndyPerthWA
« Reply #8 on: March 10, 2022, 10:10:52 AM »
Thanks for the welcome Laverda Dave, yellow is great though mine was red originally and spent most of its life black!
Thanks for the advice, I may reinstall the original jets but they are terribly gummed up
Offline AndyPerthWA
« Reply #9 on: March 10, 2022, 10:11:52 AM »
Thanks K2-K6, I'll give that a go next time the carbs are off!
Offline AndyPerthWA
« Reply #10 on: March 10, 2022, 10:12:51 AM »
Thanks for the welcome Phil, and the recommendation
« Reply #11 on: March 10, 2022, 10:18:34 AM »
[/quote]
I have found that overnight soaking in petrol & acetone make good solvents on carb parts.
Offline AndyPerthWA
« Reply #12 on: March 10, 2022, 12:09:56 PM »
Thanks Ted, I'll give them a soak and try to clean them up!
« Reply #13 on: March 10, 2022, 12:17:03 PM »
It wasn't so much the jets but the fuel cut off valve that gives the problems of leaking carbs. The new valves don't appear to seal properly hence Nigel's comment about using T-cut. I tried it but it didn't work so I cleaned up the old valves and it cured it.
Float height is also critical.
Offline AndyPerthWA
« Reply #14 on: March 10, 2022, 09:21:00 PM »
Thanks Dave, I’ll soak all the old brassware in petrol or acetone and try to scrub them back into shape
