Author Topic: Front fork strip down  (Read 3542 times)
Offline rosco
« on: May 07, 2022, 05:35:01 PM »
Stripped. The forks for re-chrome  Look what I found?… Kitchen roll packed in   Not sure why as there were no leaks The paper was dry  What are your thoughts???    Ross
Offline Athame57
Re: Front fork strip down
« Reply #1 on: May 07, 2022, 06:14:52 PM »
My thoughts? It's the bodge to end all bodges that's what I think!  :o
I brake for animals!
1978 CB400F2 named Elen.
« Reply #2 on: May 07, 2022, 06:23:35 PM »
That's a common temporary bodge, usually done just before you head for the MOT if you have a slight weep. Can't see the pont though if the seals aren't leaking 🤔🤔🤔🤔 or the forks are out of oil 🤣🤣🤣🤣
« Last Edit: May 07, 2022, 06:25:32 PM by Nurse Julie »
Offline rosco
« Reply #3 on: May 07, 2022, 06:27:11 PM »
I understand the bodge, but there are no leaks, as can be seen in photo No old staining on the paper I just don't understand why do it in the first place when its not needed ?????
« Reply #4 on: May 07, 2022, 06:30:06 PM »
Maybe a 'just in case' bodge Ross.
