Author Topic: duff spark plug  (Read 5823 times)
Offline mickwinf
duff spark plug
« on: June 16, 2022, 11:53:03 AM »
Had a morning off today so thought i would take my 550f2 for a cheeky spin, the first outing this year! so checked the tyres etc and started it up, but only fired on 3 cyls, no 3 not sparking. of course its awkward to remove but tried it on the side of the engine and sure enough dead as a dodo. Ok so plugs do wear out but i have had this problem before with my 500/550 bikes, where after being stood for a while and even if it was running fine when last used, one plug decides not to play. I always use NGK and have very few miles on them so what is the answer, do i change brand?
Re: duff spark plug
« Reply #1 on: June 16, 2022, 12:52:16 PM »
Are you sure they are genuine NGK a lot of copies out there. ;)
Re: duff spark plug
« Reply #2 on: June 16, 2022, 01:01:17 PM »
Have you tried that #3 on a lead from #4 to see if there's any different interaction (maybe a problem on #3 supply routing) just to eliminate bike based compromise.
I very rarely find a faulty NGK plug across cars, bikes and small engines, that's even after severe flooding too as they always seem to survive to spark again  :)
Not knowingly had a imitation plug but have also heard stories that they're about.
Re: duff spark plug
« Reply #3 on: June 16, 2022, 01:39:03 PM »
Yeah I'd suspect the HT lead or cap before the plug Mick.
Offline mickwinf
Re: duff spark plug
« Reply #4 on: June 17, 2022, 08:53:07 AM »
I have always bought my plugs from silvers so hope they are genuine ngk. The plug caps are new and the lead has been trimmed to make a good connection, and all i did was put another plug in and away she went. Its not a big deal but a bit odd.
Re: duff spark plug
« Reply #5 on: June 17, 2022, 08:55:41 AM »
I would go to your local motor factors mate, probably sell more and cheaper
Re: duff spark plug
« Reply #6 on: June 17, 2022, 01:04:33 PM »
I'm trying ND plugs this time around. Bought a box full when they were cheap.
Offline Orcade-Ian
    • Older Vehicle Web
Re: duff spark plug
« Reply #7 on: June 17, 2022, 05:18:56 PM »
I bought a box of 10 NGK a while ago from fleabay and fitted 4 of them to my classic Mini Estate, which has a late Cooper injection power unit.  All fine for a good while then started playing up like a bad king lead to the dizzy - except it doesn't have one! Tried a spare coil pack - no different.  Would accelerate smoothly up to the red line as long as you were gentle but if you asked too much in too high a gear, it would buck like it suddenly had no sparks on any cylinder - so much so that it buggered the top engine steady rubbers   Bought a set of Bosch plugs from our local factors and it was back to its old self.  Yes, there were fake NGKs out there - I binned the rest, lesson learned.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline Yoshi823
  • Biker to the bone...
Re: duff spark plug
« Reply #8 on: June 20, 2022, 03:11:56 PM »
I bought some NGK plugs from M&P for the Exup & had problems with 2 of them within a 1000 miles
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline Matt_Harrington
Re: duff spark plug
« Reply #9 on: June 20, 2022, 06:45:51 PM »
So much for those plugs being reliable! I thought the VX ones were meant to be one of the better plugs....
