SOHC.co.uk Forums > CB500/550
Shift shaft tiny lateral movement?
<< < (6/6)
JezzaPeach:
All good advice thanks gents.
Oddjob:
I tried Graham, hit it with a hammer and I couldn't get it past the lip. If you just tap it flush then you'll be fine.
They must have used a lump hammer to get it in that far  ;D ;D
alexdecker:
Just a quick update that Julie’s oil pump rebuild kit solved all my leak problems. Buy with confidence 😊
Nurse Julie:
--- Quote from: alexdecker on August 18, 2022, 10:12:56 AM ---Just a quick update that Julie’s oil pump rebuild kit solved all my leak problems. Buy with confidence 😊
--- End quote ---
JezzaPeach:
I’ll second that! 👍
Navigation
[0] Message Index
[*] Previous page
Go to full version
