Author Topic: Jet Set O Ring  (Read 2922 times)
Offline Davelu88
Jet Set O Ring
« on: August 15, 2022, 10:12:51 PM »
Hi All , I ordered the Keyster carb gasket set from DS and the O ring for the Jet Set does not seem as thick when put on as the old one was . Is this normal ?. Many thanks Dave
Re: Jet Set O Ring
« Reply #1 on: August 15, 2022, 10:19:02 PM »
They are not genuine O rings Dave and they are also not Viton, so not Ethanol / modern fuel resistant.
If you are concerned,  I sell full Viton Carb O ring kits for your bike.
Offline Davelu88
Re: Jet Set O Ring
« Reply #2 on: August 15, 2022, 11:04:00 PM »
Sent you a pm Julie
Re: Jet Set O Ring
« Reply #3 on: August 15, 2022, 11:55:48 PM »
Was it the full repair kit or just the gaskets you bought? Comes up regularly on the US forum that the keyster brass is not very accurate
Offline Davelu88
Re: Jet Set O Ring
« Reply #4 on: August 16, 2022, 11:14:18 AM »
Just the gaskets Bryan , it is not even close to filing the groove in the jet , just seems too loose
