Author Topic: Has anyone used these coils?  (Read 65537 times)
Re: Has anyone used these coils?
« Reply #60 on: May 27, 2024, 08:17:08 PM »
It used to be part of a Suzuki service schedule to swop the plugs 1 to 4 and 2 to 3 to even out the spark erosion wear
Online deltarider
« Reply #61 on: May 27, 2024, 09:51:42 PM »
Yep, you can do that, but personally I never felt the need, meaning: I never noticed a difference in erosion of the electrodes in such a degree that I've would have judged swopping necessary.
Online deltarider
« Reply #62 on: May 27, 2024, 09:56:57 PM »
Tried and tested by a forum member, hardly unknown!
Tested for how long? Did he have a look at the inside, the wires, the quality of the isolation in there?
If a coil is of a known brand, you can buy it, even when made in P.R.C but... if it's a non brand and made in P.R.C, look elswehere. My advice.
« Last Edit: May 28, 2024, 07:38:37 PM by deltarider »
beardylondon
  • Guest
« Reply #63 on: May 29, 2024, 12:26:38 PM »
@deltarider
Well the known brand are more expensive and I asked DS about theirs and they couldn't tell me the resistance. So I checked with Ash, and he said go for these as the resistance is documented and correct for the bike.
Thanks for your advice and feedback, I get where you are coming from, I am also wary of cheap parts especially on the Wild West which is Ebay! However on this occasion, these coils are from Hendler, a UK based company, and supplied to the company I purchased them from, also based in UK, direct link below:
https://www.hendler.co.uk/product/hendler-ignition-coil-12v-points-twin-lead-2-wires-90mm-centres-p-511oh-s-1755koh-540612h
Sounds like you had a bad experience in the past, but alas it makes no difference to me if these were made in UK or PRC, especially as I already have them and they work fine!
Time will tell ;D
« Reply #64 on: May 29, 2024, 01:55:51 PM »
I'm a Hendler fan.👍👍👍
