CB650
clutch cover/right hand crankcase
Topic: clutch cover/right hand crankcase (Read 3959 times)
kemp2368
Newbie
June 23, 2010, 07:57:49 PM »
hi all,can anyone help me
while adjusting the clutch today,the part that comes off the case and holds the clutch cable decided to break off ???has anyone got a spare cover or got any ideas how i can attach the cable/adjusting nut
thanks
cb650z,1979
florence
Re: clutch cover/right hand crankcase
June 24, 2010, 11:17:07 AM »
If it's clean, araldite might hold it but be sure to give it ages to cure. Once cured it's probably stronger than the aluminium itself. It would at least get you going until a new part can be found at the right price.
June 24, 2010, 03:41:43 PM »
There is a lot of bending moment on that part so i doubt araldite would hold but a good tig welder should be able to sort it
kemp2368
Newbie
June 24, 2010, 05:07:35 PM »
thanks,i have managed to stick it with a industrial strengh super glue we use at work(its from wurth)and to my surprise it has held so far(done about 10 miles today
the only cases i can find at the moment are from the u.s.a and all a bit pricey
does anyone no if diff models will fit??
cb650z,1979
kemp2368
Newbie
September 07, 2010, 06:10:43 PM »
got a case from the u.s.a,only worked out to be
cb650z,1979
CB650
