Author Topic: Cb550 k3 primary chain  (Read 12470 times)
Re: Cb550 k3 primary chain
« Reply #30 on: November 03, 2022, 05:36:02 PM »
I’ve just seen a squirrel…..🫣
WTF does that mean  ;D ;D ;D ;D ;D
« Reply #31 on: November 03, 2022, 05:46:50 PM »
I was a moderator on .net for many years.
This is a walk in the park compared to some of the gun threads we had to deal with.
Having said that, just agree to disagree guys.
Please.
Offline fourfive
« Reply #32 on: November 03, 2022, 10:13:00 PM »
I've decided to strip the engine and replace the chain. Trying to get the rotor off the crankshaft I screwed the removal tool into the rotor, First tried with a crack bar but no joy. Then I used an impact gun, still no joy and the threads have stripped on the rotor.
Will I damage anything using heat?
Any other suggestions welcome.
Thanks Ian
« Reply #33 on: November 03, 2022, 10:21:21 PM »
You stripped the threads, Jesús never heard of it doing that before. Try some heat, won't hurt. You need to get it off to replace the oil seal behind it.
Not sure where in the UK you are but probably a member close by with a spare rotor lying around. I've got quite a few, some are rusty but would clean up ok.
Offline fourfive
« Reply #34 on: November 03, 2022, 10:46:09 PM »
I'm near Sheffield, couldn't believe it when the threads came out. Blow torch out in the morning.
« Reply #35 on: November 04, 2022, 05:53:02 AM »
Gawd stripped rotor threads - a bit late in the day now - my experience with most similar pullers is to just nip the thread up so it's in place but not over tight. Then a good lump hammer strike on the top of the puller. If it does not budge a little more nipping up and repeat. Using a big bar or an impact gun on a puller is a no-no for me. I've had car flywheels and all sorts where the taper surfaces have part fused but they have always come out.
With the crank out you should be able to apply some impact force  from behind to get the rotor off - one side then the other with a helper holding the crank vertically if heat alone does not work.
Keep us posted with your progress.
« Last Edit: November 04, 2022, 05:54:33 AM by McCabe-Thiele (Ted) »
« Reply #36 on: November 04, 2022, 08:15:52 AM »
I’d strip the motor then go for the rotor later. I’ve found that it’s easy to use judiciously placed soft wood and progressive taps with a hammer will ease it off. Worked for me as I didn’t have a puller.
« Reply #37 on: November 04, 2022, 08:23:21 AM »
Thanks Ian
Paul Gledhill lives in the Sheffield area, he has a lot of experience and may have a puller. If using a puller, always place a nut in the hole so, not to damage the crank thread  ;)
Offline Toko_Jo
« Reply #38 on: November 04, 2022, 09:11:02 AM »
Referee! 📣📣📣 (couldn’t find a whistle)
    You will NEVER break the chain  :)  https://youtu.be/JDG2m5hN1vo
« Reply #39 on: November 04, 2022, 12:48:38 PM »
 ;D
Offline fourfive
« Reply #40 on: November 04, 2022, 09:30:41 PM »
It's finally off, plenty of heat and some well-placed hammer blows did the trick.
Has anyone got a replacement to sell me?
Thanks Ian
