gauges
Topic: gauges (Read 5699 times)
clive
SOHC Member
gauges
June 24, 2010, 06:25:42 PM »
got a set of gauges for balancing the carbs, the problem is that the manual says the reading should read 14-24 Hg, but my gauges read in bar's, has anybody overcome this problem, help appreciated.
cb500/4, 535 virago, sunny south yorkshire, apart from floods, earthquakes
matthewmosse
Re: gauges
June 24, 2010, 08:38:58 PM »
I belive the readings all being equal is more inportant then the figure they are at. The manuals normally have a section at the rear with conversion charts for various units of measurement.
PikeyBoy
Re: gauges
June 24, 2010, 08:39:53 PM »
http://www.engineeringtoolbox.com/pressure-units-converter-d_569.html
Try this link has a whole series of conversion factors
clive
SOHC Member
Re: gauges
June 25, 2010, 09:13:39 AM »
thanks chaps, pikey,i was hoping for a simpler reply,as mi brains getting a bit confused as it is
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Re: gauges
June 25, 2010, 10:29:36 AM »
Matthew's reply is the important one.
It doesn't really matter what the dials read, it is the balance that is important.
gauges
