Author Topic: Running on three  (Read 14554 times)
Offline gary123
Running on three
« on: November 05, 2022, 10:52:44 AM »
The initial start up on of my 500/4 went well, firing on all 4 but running a bit rough and petrol dripping from an overflow pipe. So I took carbs of and double checked float height's again.
Dont know why but one was way off (3). Replaced carbs, air box etc inc new filter and now No 3 wont fire at all.
If I take the air box off and put my hand over No 3 intake it strikes up till I take my hand away, do you think this is still a float height issue.
Ive double checked tappets, points, timing, plugs and leads.
Offline mickwinf
Re: Running on three
« Reply #1 on: November 05, 2022, 11:48:20 AM »
possible blocked idle passages or air leak?
« Reply #2 on: November 05, 2022, 11:51:14 AM »
Sounds initially like the idle circuit jet is not flowing fuel on that carb from your description.
When you put your hand over intake it should just draw fuell through the main jet as that's it's only route to fuel, if that makes sense.
If you've got any easy start to spray down that csrb when running to see if it'll also chime in, this would confirm it's a lack of fuel through that idoe circuit too and give you a double/cross check.
« Reply #3 on: November 05, 2022, 11:52:54 AM »
Crossed over with Mick there, both thinking along same lines though.
Offline gary123
« Reply #4 on: November 05, 2022, 12:06:08 PM »
Cheers guys, Ill get the easy start out the shed.
Offline gary123
« Reply #5 on: November 05, 2022, 12:48:01 PM »
Well the easy start brought the cylinder in, any advice on what to do now will be gratefully accepted.
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #6 on: November 05, 2022, 12:59:45 PM »
Hi just a couple of easy checks, maybe swap the plug with#4 and also drain the float bowl and measure, mine are all about 50ml. I used a cheap plastic water dispenser cup marked at 50ml, the petrol melts everything else plastic!
Ash’s excellent tip correctly says to drain tubes first for absolute accuracy, but a straight drain still gives an approx measure.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #7 on: November 05, 2022, 01:02:50 PM »
Seems to confirm no fuel flow through that idle jet, which ultimately means clearing it. These can unfortunately (similar for any small flow jets on most carbs) require a few times cleaning when getting them going again. Frustrating, but often typical as any small amount of debris from anywhere in the system can get stuck in such small openings.
You could try firstly winding the air adjustment screw fully inwards while running it (gently) until it has no air supply (essentially the same as putting your hand on the carb, but just for the idle circuit) to see if anything soft that's restriction in there will get going again.
Otherwise it's pulling at least that jet and also blowing through the associated air passage to bring it back to fully operational.
« Reply #8 on: November 05, 2022, 01:11:48 PM »
To be clear, closing the airscrew is just a measure to encourage the vacuum to draw any obstruction from the fuel jet on that idle circuit, if it supports running then it can be set back to desirable adjustment and monitor for running then afterwards.
Offline gary123
« Reply #9 on: November 05, 2022, 01:14:31 PM »
Ive tried swapping plugs and leads, made no difference, Ill drain and measure.
Offline gary123
« Reply #10 on: November 05, 2022, 01:16:10 PM »
OK Ill try all that. Thanks
Offline JezzaPeach
« Reply #11 on: November 05, 2022, 01:26:03 PM »
I think my 3 and/or 4 were slow filling up due to a combination of gummed up tank cap breather (due to over filling 🙄), a slope up in the fuel pipe, and maybe float height. After steady running it seemed like the fuel level was dropping so it struggled to reach the idle jet, being higher than the main jet, and wanted to stall, so it would run on the main jet with more throttle if I stopped, and then the fuel level ‘caught up’. Also while running, after running a bit, and changing down, blipping the throttle seemed hesitant.
I’m hoping I’ve sorted the tank cap by putting a rubber tube tight against the small hole and blowing plus squirting carb cleaner into the hole.
Offline gary123
« Reply #12 on: November 05, 2022, 06:04:18 PM »
Drained the bowls and there was an identical volume of fuel in each. So now Ive got the idle jet out . The hole that runs right through has some kind of restriction in it, is this how it should be, it looks like its meant to be there so I dont want to be ramming something down it.
« Reply #13 on: November 05, 2022, 06:19:45 PM »
Try  a wire out of a wire brush there is no restrictor just a tapered hole.
Offline JezzaPeach
« Reply #14 on: November 05, 2022, 06:24:24 PM »
There’s a whole debate about that, stand by! I didn’t see anything in mine as some were bunged up with deposits, and had to clear them out very gently using a kit of stainless slightly abrasive rods from eBay. If doing it again I’d use my digital vernier to measure the right rod. Some kits come with tiny brushes that are useful for the openings they fit in plus in my case the inlet. But best wait for more experienced comments.
« Last Edit: November 05, 2022, 06:50:52 PM by JezzaPeach »
