Author Topic: Running on three  (Read 14543 times)
Offline gary123
Re: Running on three
« Reply #30 on: November 06, 2022, 04:07:59 PM »
I have proof.
Offline gary123
« Reply #31 on: November 06, 2022, 04:09:03 PM »
But seriously mine have a "spider web" in them.
« Reply #32 on: November 06, 2022, 04:16:00 PM »
Mine are genuine, but don’t.
No they're not................... ;D
Online Sesman
« Reply #33 on: November 06, 2022, 04:17:05 PM »
Oh yes they are ….(almost pantomime season).
« Reply #34 on: November 06, 2022, 04:50:54 PM »
Ohhhhhhh, no they're.........................cant be arsed! ;D ;D ;D ;D ;D ;D ;D ;D
Online Sesman
« Reply #35 on: November 06, 2022, 05:16:09 PM »
I have proof.
Yep, that’s pretty conclusive. I stand corrected.
(Attachment Link)
Offline deltarider
« Reply #36 on: November 07, 2022, 08:42:57 AM »
There is no spider web structure. It's an optical illusion. And here is the proof. http://www.sohc.co.uk/index.php/topic,22417.msg204301.html#msg204301
Online Sesman
« Reply #37 on: November 07, 2022, 09:47:01 AM »
Nope, you are wrong and Gary123 proved it😀
Online Sesman
« Reply #38 on: November 07, 2022, 09:47:47 AM »
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #39 on: November 07, 2022, 11:44:45 AM »
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Online Sesman
« Reply #40 on: November 07, 2022, 12:14:44 PM »
To be fair mezzanine, we have been through this multiple times. I have internal photos of both genuine and pattern jets. It’s an interesting kaleidoscope effect caused by the internal drilling reduction. TBH, there is no Techncial/practical reason for anything other than a stepped drilling reduction to create effective atomisation under a partial vacuum.
Offline JezzaPeach
« Reply #41 on: November 07, 2022, 03:56:19 PM »
I agree, a carburettor specialist has said the same. Interesting that the internal drilling helps too.
Offline gary123
« Reply #42 on: November 07, 2022, 04:07:47 PM »
Ok, I have to agree it is an optical illusion. If you look down the tube while rotating it the "web" does not rotate. For me, at least, that draws a line under spidergate.
However, after following all the advice offered my bike now runs, revs and ticks over nicely on all four cylinders. Probably a bit of dirt in the jet. Thanks to all who contributed.  :)
Offline JezzaPeach
« Reply #43 on: November 07, 2022, 04:38:02 PM »
Excellent news 👍 I think I cleared a minor blockage once by using full choke and revving a bit, shame that doesn’t cure everything!
« Reply #44 on: November 07, 2022, 05:37:43 PM »
Good you've a successful outcome with fueling and now running well.
For interest, the idle jet circuit on these runs a long way up into rev range when used on light throttle. Any impairment has quite significant effect on clean running for most speeds up to about 40mph ish. It'll give you a weak cylinder further out too as the  main jet blends in with higher slide positions. Having the idle circuits impeccably clean is a big part of getting them running smoothly and consistent.
I still think there's spiders in there though ;D probably trained Japanese micro ninja spiders that know their job.
