Author Topic: CB750/500 petrol tap renovation  (Read 6530 times)
« on: January 19, 2023, 10:25:32 PM »
Just taken apart my petrol cap that came with the new tank today. All the O-rings have hardened and the 4 way rubber doughnut behind the tap itself is also hard as nails.
Got me thinking, has anyone ever worked out the Viton equivalent sizes, the parts book show them as available separately but fails to give the sizes, the most you can get is the one between the cap and the tank described as 23mm but no section width. What with DS wanting £5.54 for one and £6.01 for the other (you can bet these are old parts so most likely nitrile and not Viton and due to the exposure to modern fuels we should be looking at Viton ones as a replacement) these aren't exactly cheap but most likely the Viton equivalent will be miles cheaper. The 4 way doughnut thing I'll have to source as genuine. Float bowl is rounded off so a new one of those is needed as well.
I can guess the sizes but the ones I've taken off are really flat so getting a section size could prove tricky.
So anyone already done this?
Offline Seabeowner
Re: CB750/500 petrol tap renovation
« Reply #1 on: January 20, 2023, 06:36:58 PM »
I've used 23 x 2mm c/s for the one between petcock and tank and 28 x 2.5 (which may be a bit big but squeezed it in) for the bowl. If you haven't moved since 2017 (have an address) I'll send you them to try and maybe adjust if you feel necessary.
Presume this is about tap and not cap.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #2 on: January 20, 2023, 06:51:28 PM »
I did measure the one between tap and tank and I also thought it was around 2mm, the one under the bowl I made out to be 30mm though, that was by measuring the old one across it's widest point. Saying that I'm wondering if the sizes relate to the internal diameter rather than the external, as 28mm plus 2.5 each side would make it 33mm? I have a stack of orings lying around, I may try and see if I have any 26mm x 2mm ones, the bowl oring was actually not in bad condition and looked to be 2mm rather than 2.5mm.
I'm also wondering if the doughnut shaped one can be home made rather than paying over £6 for what is bound to be Nitrile and thus not resistant to the Ethanol in fuels these days. I measured the thickness last night and it looks to be around 3mm, I have some really good hole cutters so I just see if I can find a sheet of 3mm Viton and punch out my own, may be the way to go.
Yes, about the tap not the cap, I bought a few spare rubber gaskets for the cap some years ago, never had to use one but the cap gasket is very perished on this one.
« Reply #3 on: January 20, 2023, 07:02:44 PM »
Seems you do measure the ID of then ring, then add the cross section of the rubber. So 26mm + 2mm + 2mm is the 30mm I measured.
Found some viton 3mm sheet on ebay so I'll give that a go as well.
Cheap enough to buy 10 of each rings but appreciate the offer.
« Reply #4 on: January 22, 2023, 09:52:36 PM »
Been doing a little work on the petrol tap from the second hand tank. Just mucking about really, tidying the tap up, what started as just a little tidy up ended up being a bit OTT to be honest, let me be clear this is NOT polished, I don't intend to polish it, I may polish the lever if I feel like it. This has just been dismantled and sanded using the little abrasive discs from Amazon, anyone can do this. What started as a pretty rough casting has slowly been sanded, started with 80 grade disc, just to get rid of most of the casting marks, then progressively down the grades, 120, 240, 400, 800 and finally finished with 1000 grit disc, light green to be exact. At each stage it got shinier and shinier, however the last 2 grade discs were contaminated with buffing soap and this transferred itself onto the tap and in the end I needed to clean the surface with some Brasso felt wool, which to be honest dulled the surface down a little.
Anyone can do the same, all they'll need is a set of discs and a Dremel. I have replaced the 2 small screws holding the lever plate in place with some stainless ones, you could of course replate the originals instead or even just use the existing ones but they will rust.
It's not really that visible but I feel it looks better than that dirty grey look is normally has.
The only worrying thing is that I reinstalled the doughnut washer behind the lever, mine for some reason seems to be made of cork not rubber, it doesn't seem to be sealing as I can still blow down the brass tube with the lever in all positions, saying that the cork doughnut isn't in the best of conditions so that may be the reason.
When I get round to assembling it back together I intend to replate the plate with the markings on so it doesn't rust.
« Last Edit: January 22, 2023, 09:54:42 PM by Oddjob »
Offline mickwinf
« Reply #5 on: January 22, 2023, 10:59:27 PM »
oh crap now i need to polish something else!
« Reply #6 on: January 22, 2023, 11:22:14 PM »
Thats ace Ken, well done mate.
I'll send you some new finger tips up in the post, that lot look knackered after making such a great job of that. ;)
« Reply #7 on: January 23, 2023, 12:35:46 AM »
TBH Roo the garage was so cold today that my fingers were numb, the dirt is residue of the buffing soap. The tap was easy to do, just took me a few hours. Not 100% sure if the 550 tap comes apart but if it does it should also be an easy job to do.
« Reply #8 on: January 23, 2023, 10:21:45 AM »
The King of Bling has been at it again. Nice job on the tap Ken! Only a few hours! 🥵🥵 I’ve gone for shabby chic on mine.😉
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #9 on: January 23, 2023, 10:46:20 AM »
That looks great Ken,
When you say 'blow down the brass tube'. Do you mean the long one?  Air will always have an easy passage down that as it comes out of the reserve drilling lower down (also known as the R's hole  :))
Roo, I'll buy some of those finger ends - I can stick them on rubber gloves and go 'a burglarin'. Saw it in an old movie!
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #10 on: January 23, 2023, 10:54:08 AM »
Long time shop in Kings Road
Often with tourist having their picture taken outside when I've past there.
« Reply #11 on: January 23, 2023, 11:49:42 AM »
(Attachment Link)
« Reply #12 on: January 23, 2023, 02:17:51 PM »
Ken, never seen a cork tap seat, suggests a home brew idea. I have turned the Honda rubber ones over before now as the sealing holes have a raised lip that wears away.
« Reply #13 on: January 23, 2023, 04:07:08 PM »
Noticed that Bryan, I'm going to buy a genuine and see if that seals up the brass tube. I seem to recall that when the tap is shut it's supposed to blow anything coming down that tube as otherwise the tap is in effect constantly open. We'll see when the new seal arrives. I repaired the bowl as well BTW, it was totally rounded off by some ham-fisted amateur so I filed flat spots on it until it looked like a nut again, you can see the corners aren't as crisp as they should be. I'll buy a new bowl as well and keep that for a reserve.
I'll also measure the new doughnut seal and see how thick it is and have a look at making some replicas in Viton rubber. The back of the lever is smooth so a little silicon oil or grease on there to help it slide should stop it wearing as fast as well. If it seals as well as the original one I'll make a few and sell them on. £7 for a little rubber that TBH is no longer suitable for modern fuels is a little expensive.
Yes, Ian I did mean the long one, as above, pretty sure it should seal when the taps closed but it could be leaking past the doughnut seal, saying that, I've just remembered I have a new tap somewhere so I'll test that and see. Got the money Ian, lever in post later today hopefully or definitely by tomorrow at the latest.
King of bling, I like that. I've been called much worse over the years. Must admit to liking stuff to be shiny rather than dull. Nothing against Matt paint for instance, it can be very effective for contrast in places.
« Reply #14 on: January 23, 2023, 04:22:38 PM »
I was correct, when the tap is either shut or on reserve you cannot blow down the long tube. Just checked with my new tap.
