Author Topic: Project 550 is go  (Read 39340 times)
Offline gary123
Re: Project 550 is go
« Reply #90 on: March 10, 2023, 01:23:21 PM »
It doesn't guide anything. I think it protects the coil wires from the sharp edge of the frame seam.
Offline gary123
« Reply #91 on: March 10, 2023, 01:27:40 PM »
Next issue is the indicators seem to be to fast and both idiot lights flash whether left or right is on. Any ideas ?
« Reply #92 on: March 10, 2023, 01:31:20 PM »
Check yer earths Gary..........all nice and clean and together as should be? You'll know this but they'll flash like crazy if there's a bulb/connection incomplete somewhere, are they all working? How bad is the flasher unit, is it in reasonable nick?
Might be the switch but  check those bits first is where I'd start.
Offline gary123
« Reply #93 on: March 10, 2023, 01:35:22 PM »
Flasher looks and sounds good, Im off to recheck earths, switch should be good every thing worked when I bought it. Could it be DS indicators?
« Reply #94 on: March 10, 2023, 01:42:00 PM »
doubt it, do they all test ok and light up? there's hardly anything to go wrong its only a glorified bulb holder really?
The fact that youre getting flashing idiot lights, I would think, smells of an earth issue, bit like the old fiesta's and peugeot's that when the connectors on the boot lid got dirty it would make all sorts flasj on the tail gate flash when you put the indicators on at the back.  Plus its the easiest cash free diagnosis which is always the forst point of call for me.
Cillet Bang (however you spell it) kitchen cleaner is ace for cleaning the bullet connectors if they're grubby, bob a bit in a jar and warm slightly and use that, they come up like new. (that's not my idea, one of Julie's I think) works a treat.  As does wire wool obvs ;D ;)
« Reply #95 on: March 10, 2023, 01:57:20 PM »
Can also happen with a faulty new bulb used to be common with stop & tail light bulbs - weird how circuits find other ways to earth.
On my 400 I fitted earth wires to all four indicators to ensure a good earth all round.
« Reply #96 on: March 10, 2023, 01:59:46 PM »
Same here Ted. a bit easier too for aguarenteed outcome.
« Reply #97 on: March 10, 2023, 03:14:07 PM »
Can I enquire as to whether that part specific to the 500 models only as my 77 550 F2 doesn’t have one. Unless it’s a parts manual oversight/error and I can’t remember removing one.
The parts book doesn't show it but why it doesn't have it is beyond me, both bikes are to all intents and purposes identical in the need for one. Can't hurt to fit one I suppose.
Offline gary123
« Reply #98 on: March 10, 2023, 03:15:07 PM »
GOT IT, dodgy bullet connector. Thanks all, nearly chucked it in the dyke >:(
« Reply #99 on: March 10, 2023, 03:17:24 PM »
Sweeeet! I like it when the issues yield without too much outlay of time n money
Skills mate
Offline gary123
« Reply #100 on: March 27, 2023, 05:44:52 PM »
Can anybody tell me how to check the clutch switch, should there be continuity with the leaver pulled in or out. Ive got neither so the switch could be knackered.
Can it be disabled or by bypassed ?
Online Sesman
« Reply #101 on: March 27, 2023, 06:11:07 PM »
Clutch switch closes on operation, so continuity with lever pulled in. Yes you could link out the connections, but then you risk starting the bike in gear! It’s better to leave it open circuit so you can only start in neutral?
Online Sesman
« Reply #102 on: March 27, 2023, 06:12:30 PM »
Or even better, just replace it if it can’t be coaxed into action.
Online Sesman
« Reply #103 on: March 27, 2023, 06:14:32 PM »
Cheap copies are about £7, oem about £15-19.
« Reply #104 on: March 27, 2023, 06:28:41 PM »
I bought a switch on e-bay for my 400 it worked fine just had to file a bit off the finger end to make it perfect cost me a heady £6 from this firm.
Mine was missing.
.https://www.ebay.co.uk/itm/300184704803
« Last Edit: March 27, 2023, 06:51:29 PM by McCabe-Thiele (Ted) »
