Author Topic: Electronic ignition choices  (Read 11579 times)
Offline billdn
Re: Electronic ignition choices
« Reply #15 on: March 05, 2023, 12:56:25 PM »
So went for the Boyer with micro coils. Making brackets to mount coils . Bit miffed though as connectors on Boyer are those God awful compression bullets and 4mm to boot so won't fit my loom, without cutting one connector or the other off and replacing. Loathe to cut one's of Boyer as would no doubt invalidate warranty. Did email them to let them know but no reply as yet. Thanks all.
« Reply #16 on: March 05, 2023, 02:13:34 PM »
How about fitting a short piece of wiring using appropriate ends fitted to make an adapter provided you can hide the surplus?
Offline billdn
« Reply #17 on: March 05, 2023, 02:47:41 PM »
You read my mind Ted 👍
Offline Phil Ward (RIP)
« Reply #18 on: March 06, 2023, 10:18:14 PM »
Forgot to mention that - I changed the connections to standard type - ie, like these
https://www.ebay.co.uk/itm/152873651204
Offline billdn
« Reply #19 on: March 07, 2023, 08:40:12 AM »
I emailed Boyer to ask them if changing connections would nullify their guarantee and they're technical department replied saying that they expect some customers to change them and it wouldn't invalidate any warranty.
But still think I'll go with Ted's suggestion.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #20 on: March 14, 2023, 09:58:03 AM »
On my 500 I was thinking of something cheaper as I have new coils  - the Hondaman system sounds very good from what I have read here.
Can't say too much here at the moment but Bryan might have a system in the pipeline for me.
I have the Hondaman set up on my 750K2; it has faultlessly covered 30,000Km and on one set of points!
It is easy to fit and has the advantage that if it stops working, you can simply disconnect it, reconnect the points and off you go. (Has never happened)
CB750 K2 - See: Belfast2BelfastByBike.com
CB450 K1 - A work in progress. (Still!)
Offline billdn
« Reply #21 on: April 17, 2023, 09:46:22 AM »
I have the Boyer system (Inc power coils) on my CR750 Rep - good but you will have to make up a bracket to accommodate the coils. They perform well but haven't put much mileage on them - but had them for 30000 on my Z1 back in ty 70's and was trouble free.
I have Hondamans system on both my 500k2 and 750k2 - good value and cheap. Mark (Hondaman on the US forum) usually puts them down as return of repaired parts so no import duty (he did for me anyway)
Phil, did you notice a drop in charging voltage to battery with the micro coils. As a check I thought I'd chuck voltmeter across the battery , can't get more than 13.5v at 5000rpm , whereas manual quotes 15v at 5000rpm. Not much difference with lights on btw. It is a new battery. I also have a combined  regulator/rectifier unit from Wemoto,  which worked fine before. Maybe just needs a good run ! I'll do the usual checks on alternator etc in due course.
« Reply #22 on: April 17, 2023, 12:00:25 PM »
What are micro-coils are they like modern car coil packs?
Offline billdn
« Reply #23 on: April 17, 2023, 03:34:46 PM »
No idea Ted, came with the kit but do carry spark to ht leads then the plugs. All plugs spark but only 1 fires , or something like that.
Went for these as an ht lead on old coils was decidedly dodger and about to fall off.
« Reply #24 on: April 17, 2023, 04:15:17 PM »
If the coils are essentially double sparking then that's an additional draw on what is a very limited wattage charging system, around 150w IIRC. A Dyna system uses around 1amp more than stock coils for example and that only sparks half the time as per the normal Honda system, if it sparks double then potentially that's another 1amp loss.
« Reply #25 on: April 17, 2023, 04:30:50 PM »
So are the HT leads built into the micro-coils or do they  plug in as separate items?
Offline billdn
« Reply #26 on: April 17, 2023, 06:41:15 PM »
You assemble the ht leads from kit supplied to your own 5k ohms resistor plugs and fit them to micro coils at the other end. Coil 1 has cylinder 1 and 4 and coil 2 has cylinder 2 and 3 much as regular coils. Just the circuitry is different. Cheers Ted
« Reply #27 on: April 17, 2023, 11:09:19 PM »
Yes Bill, I get about 13.5v ish (I have a voltmeter as part of the digital speedo) but have the electrex world race alternator and lithium battery so put it down to that. But what Ken says makes sense.
