Author Topic: Clutch push rod question ?  (Read 11325 times)
Re: Clutch push rod question ?
« Reply #15 on: March 06, 2023, 12:04:00 PM »
There is one listed on e bay in 3 pieces!
« Reply #16 on: March 06, 2023, 12:25:43 PM »
They are a 3 section rod on later ones or all one section as Ash has explained. They usually break in two parts as the chain hits it.
Yours is a common problem with the seal cutting in to the rod, which will cause the oil to weep past the seal. Have loads of rods that look the same as yours .
« Reply #17 on: March 06, 2023, 01:55:23 PM »
here ya go ted £12.50 delivered (worth asking for more pics though to see any marks better)
https://www.ebay.co.uk/itm/185560330371
Note 323 part no.  ;)
Offline Rozabikes Tim
« Reply #18 on: March 06, 2023, 02:21:00 PM »
(Attachment Link)
Is it brain fade or did someone  (Graham maybe) get some made as specials?
« Reply #19 on: March 06, 2023, 03:35:35 PM »
That's broken Ash, no metal part on one end and it should have metal parts on both ends. The end missing is the end which Ted has all the corrosion on.
There is a modern Honda which uses a push rod of the same diameter but it's slightly longer, I'm looking at using one of those when or should I say IF I can do an hydraulic clutch conversion, however it may be able to be adapted for use as a normal push rod. I'll take some measurements and see. It's also 3 parts, one long rod with 2 metal ends.
« Reply #20 on: March 06, 2023, 04:01:33 PM »
I wonder if an old british dural push rod could be adapted to work🤔
« Reply #21 on: March 06, 2023, 04:08:30 PM »
It's all about the diameter I'd imagine, it needs to be the exact same as the 500 or the seal won't seal.
« Reply #22 on: March 06, 2023, 04:33:17 PM »
(Attachment Link)
Similar thought from me. Seem to recall "silver" steel used, that's a ground to diameter stock heat treatable steel, and so suitable for something like this if bought in correct diameter. You could heat and quench the ends to harden after shaping them to correct radius.
« Reply #23 on: March 06, 2023, 04:34:11 PM »
whoops .. how about this one Ken?
https://www.ebay.co.uk/itm/385439436435
« Reply #24 on: March 06, 2023, 04:36:50 PM »
(Attachment Link)
If you want a plain steel one you can use a 5 speed CB450 twin one but for some reason Honda lightened that part on the late 500K0's etc to a composite of alloy and steel combo.
« Reply #25 on: March 06, 2023, 06:31:17 PM »
That ones fine Ash.
Offline Seabeowner
« Reply #26 on: March 06, 2023, 07:02:50 PM »
(Attachment Link)
That's what I've been using for about 10 years. Had it made and treated at work. I also have a solid CB450 one, but have never tried it. I do notice that clutch bite point changes from cold to hot and thought it must be different expansion rates of engine and rod,
Modify message
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #27 on: March 07, 2023, 11:04:02 AM »
Whats all this then .. DS for 11 quid ??
https://www.davidsilverspares.co.uk/CB450K2-SUPER-SPORT-1969/part_334320/
« Last Edit: March 07, 2023, 11:06:00 AM by AshimotoK0 »
« Reply #28 on: March 07, 2023, 04:03:58 PM »
Pretty sure they would clean up OK...only surface corrosion by the looks of it
« Reply #29 on: March 07, 2023, 04:34:32 PM »
That's been on the DS site for a while iirc - unless they have a box of NOS rusted ones.
