Author Topic: 750f1 Air cleaner box seal  (Read 5573 times)
Offline Moorey
« on: March 12, 2023, 03:35:48 PM »
Does anyone have or know of a air cleaner box seal for the two halves of the box for a 750f1 they a different to the K series Or any suitable seal material to make one out of as mine seems to have turned into jelly.
Re: 750f1 Air cleaner box seal
« Reply #1 on: March 12, 2023, 04:21:49 PM »
Is at straight O ring type or shaped rubber?
Offline Moorey
« Reply #2 on: March 12, 2023, 05:51:42 PM »
Approx 7mm wide 6mm high
« Reply #3 on: March 12, 2023, 06:49:44 PM »
I've nothing but if I got desperate, I'd be looking at sliding door seals or similar to maybe modify. Getting something that shape might be tricky though.
Offline Moorey
« Reply #4 on: March 12, 2023, 07:54:04 PM »
 I'm getting fed up with looking at seal profiles. It could end up with me making one with black Sikaflex  ;D
« Reply #5 on: March 12, 2023, 08:15:40 PM »
Aaah, yup, I feel your pain
Offline Moorey
« Reply #6 on: March 12, 2023, 08:53:23 PM »
Getting closer now I know the profile description  Small Square U Seal. Now seeking one in a suitable material.
« Reply #7 on: March 12, 2023, 09:09:33 PM »
What about car door window seal
« Reply #8 on: March 12, 2023, 09:47:56 PM »
When we were in rented housing after our house fire (for 8 months)one of our puppies ate part of the double glazing front door seal - might be worth looking at some of the frame/window seals.
I managed to find some online that fitted perfectly.
« Reply #9 on: March 12, 2023, 10:16:43 PM »
(Attachment Link)
(Attachment Link)
Looks the same U section as the 750k but, can not find a part number for the 750F1 to compare.
 I could never find a U section rubber from any manufacture when i was looking to replace a 750K one. Ended up buying a Honda one  ;)
Offline Moorey
« Reply #10 on: March 13, 2023, 09:44:28 AM »
(Attachment Link)
(Attachment Link)
No it's not listed as a separate item. I have found some rubber section that looks quite promising and may need a trim with a blade but I need to measure up properly as the existing bit of seal is quite swollen. The carbs have been passing over the last couple of weeks and filled the air box with fuel knackering the seal and air  filter.
« Reply #11 on: March 13, 2023, 01:29:59 PM »
Here you go mate, as discussed. Very soft rubber and this a new one for a CB750K.
Offline Moorey
« Reply #12 on: March 13, 2023, 01:34:39 PM »
Cheers  mine has swollen considerably.  ;D ;D
« Reply #13 on: March 13, 2023, 01:43:58 PM »
I have had a look about for a 750F1 air box to try a K seal on but, don't have one here mate, sorry  ;)
« Reply #14 on: March 13, 2023, 02:45:25 PM »
