Author Topic: oil pressure  (Read 6975 times)
Offline captaindonutbikes
oil pressure
« on: July 12, 2010, 03:22:22 PM »
oil pressure light not going out when i turn it over.
no oil leaks
brand new oil
checked the scavenger pipe etc all seems flush and sealing.
started after removing the sump and clutch cover to remove the kick start mech. have decided not to run the gears on the shaft as not using it. (could this cause any drop in pressure ?)
any suggestions ?
cb550k3 cafe
Re: oil pressure
« Reply #1 on: July 12, 2010, 03:28:25 PM »
when i say gears on the shaft i mean the kick shaft mech !
cb550k3 cafe
Offline totty
Re: oil pressure
« Reply #2 on: July 12, 2010, 04:37:21 PM »
IIRC the switch earths the circuit so try removing the wire from it, if the light stays on then you have a short.
Re: oil pressure
« Reply #3 on: July 12, 2010, 05:14:18 PM »
My thoughts too.  Broken switch or wiring. I've seen a few broken oil pressure switches in my time. They leak and the oil pressurises both sides - hence no measurement!
Re: oil pressure
« Reply #4 on: July 12, 2010, 05:26:49 PM »
shall investigate guys, cheers ;D
cb550k3 cafe
Re: oil pressure
« Reply #5 on: July 12, 2010, 06:06:41 PM »
was the switch, thanks!
as an afterthought, i have got it working again but it seems a touch slow to respond to come back on, would this be the sign of a damaged switch ?
it works but seems a bit slower than it used to be (dont we all?)
cb550k3 cafe
Re: oil pressure
« Reply #6 on: July 12, 2010, 06:40:06 PM »
If it is slow to come back on (when you stop the engine), that's surely a sign of a good engine!
Re: oil pressure
« Reply #7 on: July 12, 2010, 07:17:34 PM »
wicked  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
need a bit of a boost
cheers
cb550k3 cafe
Offline Yoshi823
  • Biker to the bone...
Re: oil pressure
« Reply #8 on: July 12, 2010, 08:20:02 PM »
I have a spare oil pressure switch if need be.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
