Author Topic: Engine paint  (Read 6165 times)
Offline B11sey
Engine paint
« on: April 18, 2023, 11:08:12 AM »
I’m sure this has been covered before but does anyone know the correct colour to paint the engine cases. I’m thinking of creokote for the barrel and head and 2 pack for the crankcases.
Re: Engine paint
« Reply #1 on: April 18, 2023, 12:09:54 PM »
No idea about creokote or 2 pack but we've always used Simoniz SIMVHT31D on Honda CB four engines.
Re: Engine paint
« Reply #2 on: April 18, 2023, 12:40:09 PM »
I would do a bit of research before painting the engine with creokote and the effect this may have on keeping heat within the engine/oil and especially an engine relying on air to cool it.
« Last Edit: April 18, 2023, 01:14:09 PM by Laverda Dave »
Re: Engine paint
« Reply #3 on: April 18, 2023, 02:12:50 PM »
If it's Cerakote and not Creokote (don't you paint sheds with that?) then it's a ceramic coating Dave and actually disperses heat better than the standard paint. It's powder coat that can hold heat in, not that I've ever found it an issue.
« Last Edit: April 18, 2023, 05:32:58 PM by Oddjob »
Offline ST1100
Re: Engine paint
« Reply #4 on: April 18, 2023, 04:28:00 PM »
Out of interest: will this give a glossy or mat/dull finish/surface?
STOC #637
Re: Engine paint
« Reply #5 on: April 18, 2023, 04:44:08 PM »
It's semi gloss, semi satin, so halfway in between satin and gloss. Very similar to OEM Honda finish. If you want any photos of the engines we've used it on, which is all the engines we've built for ourselves and customers, PM me your email address and I'll send some over to you.
Offline Toko_Jo
Re: Engine paint
« Reply #6 on: April 18, 2023, 06:44:09 PM »
 All day long
Dupli-Color DE1615 Ceramic Aluminum Engine paint
Hard to get hold of now though in the UK ... much closer to original Honda enamel than any other IMHO
Offline SteveW
Re: Engine paint
« Reply #7 on: April 18, 2023, 06:46:13 PM »
Is the Simoniz paint resistant to petrol?
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Engine paint
« Reply #8 on: April 18, 2023, 08:27:36 PM »
Pretty much if you have baked it as per instructions.
Offline Charliecharlcomb
Re: Engine paint
« Reply #9 on: April 19, 2023, 05:48:07 PM »
I used to use a paint called Five Wheel Silver back in the day. Worked a treat
