Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
Its possible that the O ring is too thick and not letting the switch fit far enough into the case OR the switch itself is filling with oil.New switches are still available, same in GL 1000 and some Honda marine stuff
Quote from: Bryanj on April 29, 2023, 08:29:25 AMIts possible that the O ring is too thick and not letting the switch fit far enough into the case OR the switch itself is filling with oil.New switches are still available, same in GL 1000 and some Honda marine stuffThanks. I'm hoping the switch is OK, as it works when removed. I did pump out some dark stuff that was lurking behind the bearing, when I cleaned the switch out (with brake cleaner). I'm hoping that was the issue.The photo in the manual isn't very helpful. Does the o-ring sit inside the engine case, around the shaft of the switch, or is it outside the case, between the face of the switch and the face of the engine case? At the moment I have it outside the case and that seems to be holding the switch out a bit and the retaining bracket is on a bit of a slant. To me, that looks wrong and maybe I should have it inside the case, so the bottom of the switch has a good direct contact with the outside face of the engine case. It was dirty under there when I removed the switch, but I'm 'fairly' sure the o-ring was inside?
