Author Topic: What does the killswitch look like inside?  (Read 4279 times)
Online deltarider
« on: June 25, 2023, 03:39:43 PM »
No, no plans to open it, but I always wondered; what does the killswitch look like inside? Brass contacts? Steel? Any pics?
Re: What does the killswitch look like inside?
« Reply #1 on: June 25, 2023, 04:16:57 PM »
From memory brass contact pins on end of cables set in body with contact strip on red switch
« Reply #2 on: June 25, 2023, 05:48:39 PM »
Brass contacts set inside a bakolite type plate and a small contact plate with a spring under it inside the red plastic part of the switch.
Online deltarider
« Reply #3 on: June 25, 2023, 09:08:13 PM »
Thanks gentlemen.
« Reply #4 on: June 27, 2023, 10:13:10 AM »
If you ever have the joy of trying to put one back together after restoration, it's a memorable experience (for all the wrong reasons).
« Reply #5 on: June 27, 2023, 10:43:54 AM »
Yea ... try fitting a black kill-switch knob from a really early 750K1 to a K0. Metal pin is slightly shorter
Offline Gromitdog
« Reply #6 on: June 27, 2023, 11:15:16 AM »
Hi Deltarider
I think I have some pictures of mine when I had the switches apart a few years ago. If you email me I will send you the pictures
Best Regards
Nigel
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
« Reply #7 on: June 29, 2023, 10:09:15 AM »
…just taken mine apart… luckily the ball bearing stayed put.
« Reply #8 on: June 29, 2023, 10:59:00 AM »
And again
