Author Topic: Roo's Viffer  (Read 83594 times)
Offline philward
Re: Roo's Viffer
« Reply #240 on: September 22, 2023, 07:08:34 PM »
Well done Roo (and Ken)! Patience of a saint!
« Last Edit: September 22, 2023, 07:15:13 PM by philward »
Re: Roo's Viffer
« Reply #241 on: September 22, 2023, 07:13:34 PM »
Well done
I do love the VFRs
With the single sided swinging arm,
Elegance and style
And not to slow
Re: Roo's Viffer
« Reply #242 on: September 22, 2023, 07:22:53 PM »
Nice one buddy. 👍👍👍
Re: Roo's Viffer
« Reply #243 on: September 22, 2023, 07:23:44 PM »
'Captain Happy'  endless dad jokes, tactless Mancunian attempts at humour and not being able to get a word in.
That's ok Roo, no offense taken at all.  ;D ;D ;D ;D ;D
Re: Roo's Viffer
« Reply #244 on: September 22, 2023, 07:26:16 PM »
Must try harder
Re: Roo's Viffer
« Reply #245 on: September 22, 2023, 07:27:38 PM »
Thank goodness for that, I remember timing a 250 AJS backwards once, did it time after time until I finally twigged.
Re: Roo's Viffer
« Reply #246 on: September 22, 2023, 07:32:28 PM »
Ted, sent you a text mate re yer carbs……
Re: Roo's Viffer
« Reply #247 on: September 22, 2023, 07:57:42 PM »
OK Triumph T110, 1960 vintage with magneto. For years and years timed with a pencil down the plug hole on the rh cylinder, just once i did it on the lh cylinder and it ran like a sack of shite. Ended up checking timing on both and found 23 deg difference between cylinders due to cam ring wear and spent 6 hours with a slip stone evening it out.
Offline Rozabikes Tim
Re: Roo's Viffer
« Reply #248 on: September 22, 2023, 09:04:32 PM »
Well done "OdRoo".
Re: Roo's Viffer
« Reply #249 on: September 22, 2023, 09:05:21 PM »
Well done Roo👍. You can't keep a mighty VFR down for long. I didn't mention it at the time but there's a guy running a YouTube channel called My Restoration. It's a pretty good watch as he's done a few bikes. One of the restorations was a VFR800. He took the cams out and when he set the valve timing he got it very wrong and managed to break a camshaft! Luckily both you and Ken have considerably more skill and got it right👍
Re: Roo's Viffer
« Reply #250 on: September 22, 2023, 09:15:02 PM »
Brilliant news Roo! Happy biking! 👍👍
Re: Roo's Viffer
« Reply #251 on: September 22, 2023, 09:24:27 PM »
Well done "OdRoo".
Re: Roo's Viffer
« Reply #252 on: September 22, 2023, 09:27:01 PM »
Well done Roo. You can't keep a mighty VFR down for long. I didn't mention it at the time but there's a guy running a YouTube channel called My Restoration. It's a pretty good watch as he's done a few bikes. One of the restorations was a VFR800. He took the cams out and when he set the valve timing he got it very wrong and managed to break a camshaft! Luckily both you and Ken have considerably more skill and got it right
Yeah, saw that. Videos like that are invaluable tbh as I’m sure youre aware. We’ve all had a ‘please make that just didn’t happen’ moments!
His was gear driven cams though so couldn’t use his timing tips but took what I could from his vids
No leaks apparent as yet but expecting a weep from the front cover gasket, it was a little past it’s best but gone back on with a bit of goo as they’re about 80 quid!
Offline davidcumbria
Re: Roo's Viffer
« Reply #253 on: September 23, 2023, 07:10:06 AM »
Glad it's sorted Roo. So the tight squeeze did create a little reassembly problem as you predicted. Do you think a vfr would be OK as a restoration project or it would just be a serial pita?
Offline Matt_Harrington
Re: Roo's Viffer
« Reply #254 on: September 23, 2023, 09:19:46 AM »
Yay! Glad it is all sorted and now you can resume the other projects! Will call for a chat soon...
