Author Topic: Are CB Tank's interchangeable ?  (Read 8643 times)
Offline brinkys
« on: July 23, 2010, 12:56:04 PM »
I'm after a tank for my CB550, there are lots of tanks on ebay for various other CB's, the question that I have is are the CB tanks interchangeable ie will a CB750, CB500 (T), CB400 etc tank fit on the CB550.
Online Bryanj
Re: Are CB Tank's interchangeable ?
« Reply #1 on: July 23, 2010, 01:13:09 PM »
not straight on no
all500 and 550K to 76 are the same but f and 77/78K are different
« Reply #2 on: July 23, 2010, 02:23:34 PM »
I fitted a CB550K3 seat and tank to my 500/4 (in the avatar)
The tank is a straight swap, but it is larger than the 500 tank so won't really fit with the std seat.
The 550K3 seat fitted on after I modified the mounting brackets for the hinges as they were about 2" too far forward.
Offline matthewmosse
« Reply #3 on: July 23, 2010, 05:01:20 PM »
Fuel taps different too, the 500/4 has 2 outlets and the 550 k3 ones I have have only 1 outlet on the tank, taps are not interchangable so it's inprovisation time with the pipes if swapping tanks or carbs around, not fun as it's a tight place to route pipes in neatly and kinks or tight clearences = slit fuel lines, rubbed thru fuel lines or fuel starvation, in short a pain in the bum (ive been told that appart from the cost and smell issues of the contents of your tank spillling down your leg that there are safety issues to do with fires but at that stage getting home is normally higher up the list then that)
Offline Yoshi823
  • Biker to the bone...
« Reply #4 on: July 30, 2010, 06:16:26 PM »
I have interchanged the tanks between the K3 that I had onto the blue F2 in the past, together with the seats, without any problems.
Have a photo of the bikes like it somewhere.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
