Author Topic: Item 8 in this picture - tongued washer?  (Read 3564 times)
« on: August 02, 2023, 06:38:16 PM »
As it was missing on my 500 I am fitting the chain guard that bolts inside the left side chain case cover.
Two M6 bolts hold the protector in place, one has a spring washer, the other has a tongued washer part number 90532-323-000. that is  shown as no longer available.
Is it okay to use a spring washer instead or is the tongued washer an essential locking tab?
Do I need to fabricate a lock washer for this location?
.left-crankcase-cover_bigma000082e11_91d1 by Macabe Thiele, on Flickr
Re: Item 8 in this picture - tongued washer?
« Reply #1 on: August 02, 2023, 07:53:38 PM »
"Is it okay to use a spring washer instead or is the tongued washer an essential locking tab?"
It looks like the spring washer is on a bolt isolated from the chain run, with the tabbed bolt having extra security being in vicinity of the chain and sprocket rotation  ?
I can't tell fully from the diag, but that would make sense for the type of fixing security they provide.
« Reply #2 on: August 02, 2023, 08:23:21 PM »
Yes I can see that now you mention it - not sure where the tab locks into as it's not clear from the parts book - possibly it latches into the large round hole.
I will play safe & make a locking tab as I do not want to risk a bolt coming loose & striking the chain.
« Reply #3 on: August 02, 2023, 10:41:47 PM »
Yes, I'd view as you do Ted, in that the lock tab appears to anchor in that nearby hole to secure.
Some of the others with more experience than I of 500 could likely shed some more focused light on it for you .
« Reply #4 on: August 02, 2023, 11:36:25 PM »
I'd say you hit the nail on the head Nigel.
« Reply #5 on: August 03, 2023, 07:42:50 AM »
If you do not want it to come loose, just put thread lock on the bolt  ;)
« Reply #6 on: August 03, 2023, 08:30:44 AM »
Cheers Ken, 500 experts have better knowledge about these detail :)
« Reply #7 on: August 03, 2023, 09:01:47 AM »
Not so sure it’s knowledge Nigel, more common sense in a lot of cases and an understanding of how the Honda engineers seemed to think.
