CB750
Ignition key switch
Topic: Ignition key switch (Read 2693 times)
Pauarc
SOHC Member
Ignition key switch
August 04, 2023, 06:11:18 PM »
Is it possible to take IGNITION SWITCH apart key broken in lock
Cb750k2
Trigger
Engines built on reputation, not advertising.
Re: Ignition key switch
August 04, 2023, 06:13:35 PM »
Yes, it can be taken apart. Try a good strong magnet to remove the broken part of a key
Pauarc
SOHC Member
August 04, 2023, 06:32:02 PM »
How do you take them apart I have a couple of spare keys I would like to keep all locks the same have got lock off tried banging on rubber mate
Cb750k2
Trigger
August 04, 2023, 06:36:26 PM »
If you have the lock off, squirt a load of WD40 in the lock and bang on the edge of a wooden block . Too many ways to remove a key, including a dab of super glue on the key and attach a dowel of wood
Pauarc
SOHC Member
August 04, 2023, 06:44:48 PM »
I will have a go in morning thanks hope it works
Cb750k2
Oddjob
August 04, 2023, 08:32:49 PM »
If it's the lock that goes between the clocks that comes apart fairly easily, the one under the tank isn't so easy. Seat locks are easy to get apart.
Trigger
August 05, 2023, 07:27:42 AM »
This may help >>>
https://www.youtube.com/watch?v=AMzEuXVrOw4
Pauarc
SOHC Member
August 06, 2023, 10:07:36 AM »
Got key out kept banging on wooden bench just got to put back on bike
Cb750k2
Trigger
August 06, 2023, 10:18:53 AM »
Well done. Sometimes it is the easiest solution
CB750
Ignition key switch
