Author Topic: Doms CB550F1 project  (Read 440427 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #615 on: June 09, 2024, 05:06:48 PM »
At 2 turns out it seems ro run and idle better, it'll still start with no choke though from cold so must still be quite rich, until I can get to the bottom of why I have no speedo and rpm readings I can't really take it out nor play with carb fine tuning
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #616 on: June 18, 2024, 06:19:48 PM »
Bit of a snorkel question, apart from the obvious job it serves to keep out water is there any tuning or performance reason to have a snorkel fitted to the top of my filter lid or could I just mount some mesh over the lid opening?
« Last Edit: June 18, 2024, 08:20:34 PM by DomP »
1975 XS650B
« Reply #617 on: June 18, 2024, 08:56:47 PM »
Originaly for noise supression in certain european countries (Germany) came with smaller jets as airflow restricted so if you use open lid would suspect you would need the 500 jets
Offline DomP
« Reply #618 on: June 18, 2024, 09:09:28 PM »
I've got the lid Bryan so if I fitted the lid to narrow the opening and mesh it to prevent leaves etc would I be OK to run the standard 550f jets do you think?
1975 XS650B
« Reply #619 on: June 19, 2024, 08:07:10 AM »
Dont know Dom, all you can do is try it and see
« Reply #620 on: June 19, 2024, 10:18:56 AM »
Someone told me the main reason for your different jetting was more to do with it being a 4 into1 rather  than just the air box.
« Last Edit: June 19, 2024, 10:21:28 AM by McCabe-Thiele (Ted) »
Offline DomP
« Reply #621 on: June 19, 2024, 11:41:20 AM »
Will give it a go Bry.  Yeah I read that somewhere Ted
1975 XS650B
« Reply #622 on: June 19, 2024, 11:57:03 AM »
The top tool tray is not a close fit to the airbox anyway,  It's probably just designed to keep water from the seat out of the air intake.
« Reply #623 on: June 19, 2024, 01:39:15 PM »
Thats the 500 Ted the 550 snorkle is held down to the filter box with long wing nuts
« Reply #624 on: June 19, 2024, 03:20:50 PM »
My bad I was thinking it was a 500, presumably the 550 might have some sort of vent circulation from the cam case cover as well for reduced emissions?
« Reply #625 on: June 19, 2024, 05:04:09 PM »
It does Ted
Offline DomP
« Reply #626 on: June 30, 2024, 02:18:34 PM »
I really haven't much to update on my project lately, I've been held up laying a brick plinth for my workshop build.  I've tried to set up the magnetic speedo sensor supplied by Koso but can't get a reading yet. The speedo converter I got from Digital Speedos was definitely incompatible, attempts to contact them by phone and email have all been ignored so be careful using this company.
Hopefully I will have finished my brickwork by the end of next week so should be able to turn my attention back to the 550!
1975 XS650B
Offline DomP
« Reply #627 on: July 04, 2024, 09:56:14 PM »
I did something!  My airbox had no lid or brackets to hold a lid on, thankfully Nige on here helped me out with a 550f lid so other than stripping and repainting it all I needed to do was make some brackets and weld some m5  threaded bar to them to locate through the lid holes.  It's worked out really well so all I need to do is make a new seal and mesh the opening,  the snorkel won't fit below mu home made seat base but I'm not sure it affects the running but is there more to prevent rain ingress...I could be wrong.
Top tip - remember to take the chuck key out of your pillar drill BEFORE turning it on!   Chuck key still yet to be found.
1975 XS650B
« Reply #628 on: July 05, 2024, 08:12:51 AM »
[/quote]
Thankfully it wasn’t imbedded in the soft tissue somewhere!😳
« Reply #629 on: July 05, 2024, 12:08:54 PM »
[/quote]
I hope that it didn't hit any bike parts on it's solo flight!
