Author Topic: Doms CB550F1 project  (Read 442792 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #15 on: August 13, 2023, 07:11:00 AM »
Yes you're correct Trigger, looks like they've tried to drift the emulsion tube out...rather unsuccessfully!
It's no.4 carb I need but having all the spares might come in handy, I didn't expect this to be plain sailing, twice as many carbs as my xs😆
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #16 on: August 13, 2023, 07:13:23 AM »
I thought the keihin 069a were a more commonly used carb? Barely any or their parts on Ebay
1975 XS650B
« Reply #17 on: August 13, 2023, 07:17:06 AM »
You drift the tube out from the other end, needle side  ;) If it was plain sailing, you would be bored by now  ::) Having a spare set usually works out cheaper in the long run.
« Reply #18 on: August 13, 2023, 07:19:57 AM »
The earlier carbs are more available from imported bike being broken for spares  ;)
Offline DomP
« Reply #19 on: August 13, 2023, 08:05:24 AM »
True, plenty to keep my occupied this winter I think.  A full spare set in decent condition could be a godsend actually, I'll message the ebay link you sent me to check their condition under the bowls.  Thanks for your help too!
1975 XS650B
« Reply #20 on: August 13, 2023, 08:50:33 AM »
I had a shed load of carb body's that i cleared out last year. Julie put them on ebay and sold all within a month.
Most owners damage (Snap off ) the float pin towers trying to get the pin out. I have always found that if, they are well stuck in. It is easier to run a thin blade down the side of the towers and cut through the brass pin. Cheaper to replace a in than a carb body  ;)
Hope you get a result .
Offline DomP
« Reply #21 on: August 13, 2023, 02:40:38 PM »
Amazingly the Ebay seller of those carbs is unwilling take the bowls off to enable me to check the condition.
1975 XS650B
« Reply #22 on: August 13, 2023, 03:28:08 PM »
That might be because he knows they are not very good inside.
« Reply #23 on: August 13, 2023, 06:47:48 PM »
Well, that's a poor show, they probably have no internals in them 😂😂😂
Offline Seabeowner
« Reply #24 on: August 13, 2023, 06:52:18 PM »
Equally amazing they sold in a day. Did you buy them?
If they were listed as used, they must be serviceable. But just looked they are just marked pre owned, so maybe anything goes.
« Last Edit: August 13, 2023, 06:56:46 PM by Seabeowner »
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #25 on: August 13, 2023, 06:58:52 PM »
I would of taken a chance as, not listed as spares and repair  ;)
« Reply #26 on: August 13, 2023, 08:06:45 PM »
I have a spare number 4 carb body, 069a, and most of the internals for the rest of the carb bodies, I'm just waiting for Dom to see if he needs anything else besides the carb body, an emulsion tube and the jet leaf spring. Looking at the state of his carbs it's likely that he will.
Offline DomP
« Reply #27 on: August 13, 2023, 09:00:49 PM »
I wasn't prepared to take the chance given his response, removing 4 screws per bowl would take all of 5 mins.  Any way I've carefully drifted all four emulsion tubes out, no4 is damaged although the internal orifice that the needle enters is ok but really needs replacing, other than some float straightening on all other carbs they are good.
In short I think I need the body of carb no4, it's emulsion tube, main jet and the retaining spring, or just a complete no4 carb.  I've spent most of this afternoon stripping the black rattle can paint off them, carb cleaner wrinkles it up nicely.
1975 XS650B
« Reply #28 on: August 13, 2023, 11:22:18 PM »
The needle enters the emulsion tube and that is its guide  ;)
Did you get all the float pins out OK ?
Offline DomP
« Reply #29 on: August 14, 2023, 08:02:37 AM »
All float pins came out easily Trigger, the pin entry end of the emulsion tube is only slightly marred on the top edge but I'll replace it anyway.
1975 XS650B
