Author Topic: Doms CB550F1 project  (Read 442776 times)
Re: Doms CB550F1 project
« Reply #270 on: September 12, 2023, 10:45:26 AM »
I have had loads of rods that needed re claiming, which you can not see that they are out with the human eye over the years and quite a few twisted rods even on SOHC's.
As for the price of the correct measuring equipment it can be very expensive and take a lot of experience to use correctly.  ;)
« Reply #271 on: September 12, 2023, 12:31:21 PM »
Not sure what is meant by reclaiming a con rod Graham?
« Reply #272 on: September 12, 2023, 02:25:20 PM »
I think the yanks call it resizing but, i have always known it as reclaiming. I use a Sunnen machine  ;)
« Reply #273 on: September 12, 2023, 03:01:16 PM »
Ted, normal a rod goes oval with the dimension across thr bolts staying standard and other way from rod o cap getting a bit bigger so you carefully take a small amount off the pads with bolt holes in then hone the hole circular again
« Reply #274 on: September 12, 2023, 04:19:15 PM »
That sounds an amazing process - presumably you can still fit an off the shelf bearing shell, I guess were talking a really small amount of metal removal.
« Reply #275 on: September 12, 2023, 06:17:29 PM »
Yes, back to standard spec. And you have to do all the rods the same to keep the weight right  ;)
Offline Seabeowner
« Reply #276 on: September 12, 2023, 06:47:20 PM »
Plastigage is cheap. But if you measure out of spec with the clearances and if you can't rely on the crank being as new then you have to buy (or borrow) a pair of new shells to do the measuring with.
« Last Edit: September 13, 2023, 07:18:07 AM by Seabeowner »
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline DomP
« Reply #277 on: September 16, 2023, 03:48:46 PM »
I've spent the morning plastigauging my crank, the results are very consistent. I won't bore you with every journal but they are to my eye identical across the entire crank, an enjoyable process!
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #278 on: September 16, 2023, 04:54:00 PM »
Cant remember spec, is that within?
Offline DomP
« Reply #279 on: September 16, 2023, 05:04:16 PM »
Haynes says 0.02 to 0.048
My readings were when torqued to the lower end of the range
« Last Edit: September 16, 2023, 05:06:18 PM by DomP »
1975 XS650B
« Reply #280 on: September 16, 2023, 05:15:49 PM »
Clearance is fine then
Offline DomP
« Reply #281 on: September 16, 2023, 06:06:20 PM »
Thats a relief 🤪
1975 XS650B
Offline DomP
« Reply #282 on: September 17, 2023, 07:57:37 PM »
Im putting together a DS order for gasket set, primary drive rubbers etc, I'm sure I've read any removed circlips must be replaced with new ones, one looks a Honda specific part but are the rest easily and cheaper to source from Ebay etc?
1975 XS650B
« Reply #283 on: September 17, 2023, 09:04:36 PM »
Not the gearbox ones, use Honda. The rest should be ok.
Offline DomP
« Reply #284 on: September 17, 2023, 09:31:28 PM »
Do you mean I can reuse the ones under the clutch cover Ken?
1975 XS650B
