Author Topic: Cam sprockets  (Read 5479 times)
Offline Matt_Harrington
Cam sprockets
« on: August 14, 2023, 06:34:06 PM »
Rummaging for parts to finish off my engine rebuild I discovered I have 2 different types of cam sprocket - is one later or earlier than the other?
Re: Cam sprockets
« Reply #1 on: August 14, 2023, 06:43:23 PM »
Never seen the type on the right before 🤔🤔🤔
Re: Cam sprockets
« Reply #2 on: August 14, 2023, 07:02:20 PM »
The one on the rights is as per the parts diagram - (Issue 4 - 1977)
Deciphering things a bit more, the one with cut outs is an earlier one and the solid one is later. I presume the solid one is a bit better.
I wonder why it was beefed up so much?
Re: Cam sprockets
« Reply #3 on: August 14, 2023, 07:22:43 PM »
To help stop cam chain rattle noise. I remember now hearing about those very open ones but never seen one up close and personal.
Offline robvangulik
  • Honda Fourever
Re: Cam sprockets
« Reply #4 on: August 15, 2023, 10:21:17 AM »
I've been using one like that for years now, never heard a rattle yet ;)
Less weight is always good!
Re: Cam sprockets
« Reply #5 on: August 15, 2023, 06:28:18 PM »
My original 400/4 I restored back in 1991 has the thinner cam sprocket. When I restored the blue 400/4 about 5 years ago the cam sprocket was the two piece type. I can't say the thicker sprocket reduced the chain rattle noise though as I had both bikes running at the same time once to compare the original 400/4 exhaust with the DS replica. The 400/4 'rustle' sounded exactly the same on both bikes.
Re: Cam sprockets
« Reply #6 on: August 15, 2023, 06:31:08 PM »
I'm with Rob, if no significant difference then lighter weight has to be beneficial. I'll probably fit the one that comes to hand first!!  :o
Re: Cam sprockets
« Reply #7 on: August 15, 2023, 06:50:52 PM »
Same as on the CB750's. Solid sprocket on the early models , lighter cut out sprockets on the later models.  ;)
Re: Cam sprockets
« Reply #8 on: August 16, 2023, 09:07:59 AM »
Graham, my parts book says the one with holes is the earlier one and the solid one is later. Did you mean the same for the CB750's or the opposite?  ???
Re: Cam sprockets
« Reply #9 on: August 16, 2023, 09:30:21 AM »
Are they interchangeable ? i.e later one can beused on K0
Re: Cam sprockets
« Reply #10 on: August 16, 2023, 10:25:12 AM »
Sorry Matt, what i meant was the 750 was a lighter sprocket on the 750's latter .
The 400's had the solid sprocket on the 1977 and 1978, this was a superseded part to reduce the cam chain rattle. I did have a Honda sheet for this upgraded sprocket somewhere.
Re: Cam sprockets
« Reply #11 on: August 16, 2023, 10:29:16 AM »
Never tried it mate. Have always fitted the correct sprocket to the right cam shaft. It should not matter as it is the same size , just lighter  ;)
