Author Topic: Camshaft sprocket bolts torque setting?  (Read 4062 times)
« on: September 14, 2023, 06:39:25 PM »
No values in my Haynes Manual - downloaded Honda manual desription is for knock bolt (7 x 12) 11.5 to 14.5 ft-lbs is this the same thing?
Re: Camshaft sprocket bolts torque setting?
« Reply #1 on: September 14, 2023, 07:23:31 PM »
Odd, mine says it's 10.1-10.8 Ftlbs
« Reply #2 on: September 14, 2023, 07:24:33 PM »
My actual manual says the same as you stated first.
« Reply #3 on: September 15, 2023, 12:52:23 PM »
My Cycleserve  manual  has the same figures as Haynes so I'll go with at one.
What is the best way to stop the cam from turning whilst torquing it up I do not want to damage anything - Rotor bolt with a spanner on it?
« Last Edit: September 15, 2023, 12:54:43 PM by McCabe-Thiele (Ted) »
« Reply #4 on: September 15, 2023, 03:16:08 PM »
Probably
« Reply #5 on: September 16, 2023, 02:59:26 PM »
Managed to Torque up the cam sprocket without having to take of the alternator cover off to get at the rotor bolt.
I found that if the top bolt was just to the left of being at the top you can Torque it up as the tightening action holds against the sporocket rotating - at the top it rotates down clockwise, too far on the left & it rotates anticlockwise.
Looking at the manual there are 6 Copper washers on some of the cam cover bolts - just wondered why this is if anyone knows ?
« Reply #6 on: September 16, 2023, 03:30:32 PM »
Only soft washers i remember are the ones between end brackets and cam cocer
« Reply #7 on: September 16, 2023, 04:11:16 PM »
The workshop manual shows the locations - I'm thinking it's just for those six places that need to seal against oil?
Suprisingly the manual does not show a tightening sequence for the cam cover so my thinking is similar to the cylinder head working from the center diagonally outwards in stages until the final torque setting is reached.
« Reply #8 on: September 16, 2023, 05:57:39 PM »
Yes there are soft washers fitted to quite a few of the cover bolts.
