Author Topic: 400/4 Caliper bolts  (Read 6522 times)
Offline Matt_Harrington
400/4 Caliper bolts
« on: October 21, 2023, 05:49:01 PM »
Anyone know if the 2 bolts securing the calliper to the bracket are high tensile. As the brackets/calliper are cast ally, I was wondering if high tensile was required. The existing bolts are unmarked and of course, have a smaller head but this could be overcome with a socket head.
« Last Edit: October 24, 2023, 04:28:07 PM by Matt_Harrington »
Re: 400/5 Caliper bolts
« Reply #1 on: October 21, 2023, 05:58:29 PM »
They resist all of the hydraulic pressure exerted by the brake system, without that it wouldn't be able to brake as the two halves of caliper would be pushed apart. In other words, maximum tensile loading of system.
Location in shear (trying to gonround with the disc) is relatively easy  for a bolt of that cross section.
« Reply #2 on: October 21, 2023, 06:15:53 PM »
Somehow I was thinking that the ally thread was the weaker point. So you are saying the standard Honda caliper bolts are high tensile? (8.8, 10.9....)
« Reply #3 on: October 21, 2023, 06:21:07 PM »
Actually, thinking about it, it probably depends on the depth of thread - and the bolts do go in quite a way to the retainer plate.....
« Reply #4 on: October 21, 2023, 06:22:09 PM »
Yes, to high tensile but unsure of specific rating as I don't think they are marked generally by Honda to help with information.
« Reply #5 on: October 21, 2023, 06:23:52 PM »
As I suspected!  ;D
« Reply #6 on: October 21, 2023, 06:23:56 PM »
What rating are they torqued to in manual?
« Reply #7 on: October 21, 2023, 06:24:53 PM »
I'll check later - off to the pub for pre match drinks!  :o
« Reply #8 on: October 21, 2023, 06:44:57 PM »
I’ve used stainless steel bolts in this location for many years, no problems. I have found the correct bolts with the correct sized heads at Middletons.
« Reply #9 on: October 21, 2023, 06:56:27 PM »
Sorry got to ask it, where did you get your 5 cylinder Honda from?
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #10 on: October 21, 2023, 07:01:45 PM »
Allen Millyard went round one evening and did it Bryan,
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #11 on: October 21, 2023, 07:16:03 PM »
But that would be a 500/5
« Reply #12 on: October 21, 2023, 07:47:23 PM »
Wouldn't that be a Benelli  ;D
« Reply #13 on: October 21, 2023, 09:40:03 PM »
Nah they did 500/4 and 900?/6
« Reply #14 on: October 21, 2023, 09:53:41 PM »
Think it was a 750/6 Bry, just a 500 engine with 2 cylinders added.
