CB750
Motul oil
Topic: Motul oil (Read 7668 times)
Pauarc
SOHC Member
Motul oil
November 01, 2023, 02:46:29 PM »
Does anyone know if Motul 3000 4T 10w40 Mineral Oil has got zddp in it or can it be added and would it be worth adding
Cb750k2
McCabe-Thiele (Ted)
Re: Motul oil
November 01, 2023, 03:26:39 PM »
We have been here before Paul I suspect for commercial reasons many oil brands do not show the make up of additatives like zddp. I think agreement was for the 750 high zinc contect is essential for other less beneficial or unsuitable.
http://www.sohc.co.uk/index.php/topic,29416.msg283715.html#msg283715
Last Edit: November 01, 2023, 03:29:08 PM by McCabe-Thiele (Ted)
Link to my full restoration
McCabe-Thiele (Ted)
Re: Motul oil
November 01, 2023, 03:34:09 PM »
This article is interesting.
https://rislone.com/blog/engine-oil/the-effects-of-zinc-oil-additives-on-older-engines/
Pauarc
SOHC Member
Re: Motul oil
November 01, 2023, 06:07:43 PM »
I am clutching at straws now just can’t get a good gear change have fitted new clutch plates and steel plates I also change the adjuster in the clutch new cable I may try castrol gtx classic 10w40 mineral which has got zddp in it but it looks like engine out and look at gearbox is there any other options
Cb750k2
Johnny4428
Re: Motul oil
November 01, 2023, 06:25:36 PM »
More liable to be a problem with the selector mechanism. I take it you have had a look?
Pauarc
SOHC Member
Re: Motul oil
November 01, 2023, 06:49:47 PM »
Yes I been through selector mechanism change some of that I did notice that there not a lot of oil around the clutch
Cb750k2
Nurse Julie
Re: Motul oil
November 01, 2023, 07:02:19 PM »
Thinking about it logically, if you've ridden the bike and the new clutch hasn't burnt out, there must be enough oil getting to the right place.
Edit... Is it all gears or just 1st gear that's the problem?
Last Edit: November 01, 2023, 07:04:44 PM by Nurse Julie
Pauarc
SOHC Member
Re: Motul oil
November 01, 2023, 07:15:29 PM »
Bad changing on all gears get worse when hot
Cb750k2
K2-K6
Re: Motul oil
November 01, 2023, 07:57:20 PM »
Aah, I get the angle now
Zddp isn't likely to affect that in any significant way. It's ultimate function is too stop cold welding of two parts under the most extreme pressure, not as general lubrication. As I understand it from studies I've looked at some years ago, present in the range of 800~1100 ppm proved to be optimum but was specifically related to camshaft lobes and followers, this is tge principal reason for inclusion in older engine.
Worthwhile asking you to describe what specifically is the effect you're getting in regard to changing gear to discuss further. Is it going up down, clutched or not etc? I dont feel it's the oil doing it.
Pauarc
SOHC Member
Re: Motul oil
November 01, 2023, 08:41:59 PM »
Bike drag’s and clunky when selecting 1st then if I change up the box slowly not to bad odd times it may miss a great but not the same gear when coming down the box clunky and hard to change some time it goes into neutral ok get worse after a run and bike get hot tried setting adjuster with no gap no difference just slips
Cb750k2
Pauarc
SOHC Member
Re: Motul oil
Reply #10 on:
November 02, 2023, 07:50:40 AM »
Should you be able to just pull clutch outer off when you remove thrush washer mine fit loose (after removing plates)
Last Edit: November 02, 2023, 07:53:50 AM by Pauarc
Cb750k2
Martin6
SOHC Expert
Re: Motul oil
Reply #11 on:
November 02, 2023, 09:20:47 AM »
That ought to be fine, provided there's no play on the shaft (ooh mrs.!) when it's fully home. Not been into the Honda, but have on other bikes and they were a nice snug fit, but easy to pull off by hand.
Martin6
SOHC Expert
Re: Motul oil
Reply #12 on:
November 02, 2023, 09:26:45 AM »
That finger at 10 o'clock looks pretty notched, that could inhibit clutch plate movement?
Pauarc
SOHC Member
Re: Motul oil
Reply #13 on:
November 02, 2023, 10:10:48 AM »
Hi Martin
Well spotted will have to check may be flash giving a shadow look at some other pictures can’t see it but I will have to check
Thanks for your reply how’s your engine going
Paul
Cb750k2
Pauarc
SOHC Member
Re: Motul oil
Reply #14 on:
November 02, 2023, 12:19:21 PM »
Picture of linkage can anyone see any problems
Cb750k2
CB750
Motul oil
